Help ID this running light
Caca Cabeza
Alas, a wave took off the port side light. it measures about 4" high, 4" fore/aft and 3.5" deep.
longy
Overlord of Anarchy
6,793
1,138
San Diego
^^^ that is correct. They have a lever that hides behind the case that "locks" the unit to the mount tab - these usually don't work, and the light can be lifted off the mount easily. Also the wiring attaches to spring loaded pins and can pull the pins down from the bulb
Borax Johnson
104
Thanks!
True about the lever that helps keep the ocean away from the light. No, it doesn't. The latch won't stand up to a good sized wave; hence the need for the new light. I appreciate the reference!
Blitz
112
A wave in the ocean, chance in a million.  At least the front didn't fall off.
