Wanted to canvas opinions on a reasonably big decision I have to make soon and there are usually clued up people on this board.
Boat is a 1997 Projection 920 (similar to a J/92s I suppose?), 30ft with frac rig and bowsprit for asym kites. Predominantly used for 1H/2H inshore and cat 3 offshore racing.
I had the rig craned out this year for an inspection given that the standing rigging is about 10 years old. The rigger has effectively condemned it and looking at it I am not surprised. Previous owners have variously (i) added a masthead spin halyard, (ii) filled the inside lower quarter with foam (keel stepped, stopping leaks), (iii) drilled drainage holes and (iv) added a load of heavy brackets at the masthead. At some point the chainplates were moved 30cm aft, allowing swept spreaders to be fitted and a swap to non-overlapping jibs.
Would appreciate thoughts on a couple of key decisions which are all variants of the ratings vs performance vs cost equation. Planning to buy new main and jibs (replacing 2016 Nordac).
All the above in context of a reasonable budget for a 20+ year old boat targeting mid-fleet Solent performance on a good day.
Attaching some pics showing the as designed chainplate location and the current setup.
- Stick with current dimensions or redesign (given evolution from CHS to IRC, swap from overlappers to jibs). I don't really want to buy new kites (frac and MH) so that may be a limiting factor
- Carbon or alu (boom / stick / spreaders)
- Replace boom or hack current
- Slugs or bolt rope
- Rod/wire standing rigging
- Many others I have missed
