Ouch....I wish I had that rating. That was the rating given out of the box to Hendersons. My original rating for the boat was 39. Two weeks later it was changed to 36.
That's a bit of tough love. The boat probably belongs at 45I wish I had that rating. That was the rating given out of the box to Hendersons. My original rating for the boat was 39. Two weeks later it was changed to 36.
Rates 45 (base) in PHRF NE and that's still a tough number to sail to...
Partly because at the time a Synergy 1000 was being driven very hard by a very good crew. And Rated at 54 it was logical to put the Hendo 30 level with the S1000 that was beating it. Gardy is a good boat with a good crew, but in the races that we beat her, it was mostly starting line and course strategy that did it. We were ALWAYS hearing the footsteps behind us...Gardyloo started out in 2007 at 48, then adjusted to 54. Bad Kitty in Victoria rates 57, Girlfriend in Des Moines rates 57. Gardyloo is rated with a larger main. Race with Mumm/Farr 30's at 54 and FT10s at 57 here in the northwest
Please let me know how the new races work. We have to fix the bearings every few years.Here is a guide I put together in the last 20 minutes for a couple of guys on how to dissassemble the Henderson rudder bearings. I haven't really proof read it in detail. Let me know if it doesn't make sense or if it needs more detail
Eerie.
Guide to disassemble the Henderson 30 rudder assembly.pdf![]()
Where do you race your boat?Thank you for the update.
Still not sure what we are going to do but we will be doing something shortly.
I tried it with a 135 genoa and a -1 for fat head main, but had a 155 genoa made .... Wow what a difference... Crew weight is key... If you lots of light weight females, then 10 people is not unheard of. It is all about keeping the boat balanced.Turd Sandwich said:There is something to be said for re rating that boat with a bit less roach and a 135 as the biggest headsail to get the boat in the 50's if you live in a breezy venue. With the big main having a normal roach main for big air is a must have fuck a reef. With that rigs barely swept spreaders I always felt that the leech tension on the main did a lot to keep the rig in the boat with the kite up. With a reef in its just you, the tiny backstay and a cantilevered top mast.
I added Melges 32 knees under my stanchions right after I got the boat. I had no problems with stanchions, but wanted to stiffen the boat up.We're wrapping a solid 5th season on the Heart of Gold (#119) up in Boston. For anyone considering a Hendo, here's what we think we've learned:
1) Reefing sucks.
2) We got a big-foot #2. It's damn fast.
3) Sailing at 1450ish lbs is fast. Since we have ladies aboard, that means 8-9 bodies, with 8 as the sweet spot for rail real estate.
4) That 8-13ish kts of breeze pre-plane bracket sucks. We have a very tough time fighting IMX-40s etc. in those conditions.
Regarding how the boat's holding up, I'd say remarkably well. We've had to address soft spots under the rear stanchion bases, caused by years of hiking, but beyond that, it's in great shape. The scariest day we've had was a big-breeze Buzzard's Bay Regatta, where we managed to take a massive amount of water in around the bowsprit port...that may be a design flaw, as we've tried lots of different gasket materials without a lot of luck.
Been sailing on the hendo Mojito on Lake Erie and we have found that if we can have the 155 up we are almost untouchable upwind against our local phrf fleet.I tried it with a 135 genoa and a -1 for fat head main, but had a 155 genoa made .... Wow what a difference... Crew weight is key... If you lots of light weight females, then 10 people is not unheard of. It is all about keeping the boat balanced.Turd Sandwich said:There is something to be said for re rating that boat with a bit less roach and a 135 as the biggest headsail to get the boat in the 50's if you live in a breezy venue. With the big main having a normal roach main for big air is a must have fuck a reef. With that rigs barely swept spreaders I always felt that the leech tension on the main did a lot to keep the rig in the boat with the kite up. With a reef in its just you, the tiny backstay and a cantilevered top mast.
I know other owners who only carry the155 to 8 kts true and goes down to a 142. I keep the 155 up to 15 kts if I have full crew. The 155 is a weapon in light air!
