I thought about that one. 15 and 16 are my future upgrades. For now, I am interested in a step up above the Wave.F16 can be sailed and raced solo with main plus gennaker setup . Or two up with jib.
You're perfect for soloing an H16. I'm 160 lbs - still have to lose some weight or turn it into muscles. I won't be able to right H16, maybe after some more experience, but not now. I have no crew. I've rented Waves many times and outgrown them. I was solo sailing all times. I think I can deal with a Topaz 14cx, but then I will possibly get bored of it soon too.Some of it will depend on your weight. I'm a big guy 6'5" and 280lbs. Too heavy for a H14 and about right to count as both crew on a H16. So, I generally solo my H16 which works fine-ish. The weight is right but its a lot of lines and controls for one person to manage, especially if you are thinking trapeze. Also consider the availability of your crew. I can rarely get my crew out anyhow, so something that works for me solo gets a lot more hours on it.
I think both 460 will work solo (it talks about being a single-trapeze boat). Nacra 15 One definitely works - the main is smaller and lower making it easier to right, but I can right my standard N15 at 80Kg (takes some work though).I thought Nacra 15 was designed for the youth. Yeah, ONE rig will be FAST solo.
It says single trapeze, but I am guessing it means the tillerman sits on the hull. I've seen only one photo of a solo sailer on 460.I think both 460 will work solo (it talks about being a single-trapeze boat). Nacra 15 One definitely works - the main is smaller and lower making it easier to right, but I can right my standard N15 at 80Kg (takes some work though).
460 looks easier, less technical. Blast around.
A N15 will be a lot more technical, but also, probably has more of a resale market given N15 is a youth class, pathway to Olympics...
The side stays are attached to the tramp rail. They corrode at that point, chain plate joins section.What are the things to be careful with buying one?
RIP Mr Quinn, one of the good ones taken far too earlyThey still make H14s.
one example- http://hobiecat.asn.au/the-hobie-14-hybrid/
I saw that on the AU Hobie site. I was thinking that they hadn't update the website since 2004.They still make H14s.
This thread is getting more and more depressing. maybe I should give a serious consideration to Topaz 14cx. Couldn't be that bad.I see that Hobie has just ditched the 14 and 16.
Hobie switch to Starting Line distributer, includes manufacturing? :: Catamaran Sailboats at TheBeachcats.com
Catamaran sailing repair tips, pictures, forums and classified ads catamarans for sale by owner Hobie, Nacra, AHPC, Solcat, Aqua Cat for sale.www.thebeachcats.com
Press — Starting Line Sailing
Get the latest news and updates from Starting Line Sailing.startinglinesailing.com
Could be good or bad news for the Hobie Cat sailor. Time will tell
i didnt see hobby 16 being axed though in the article.I see that Hobie has just ditched the 14 and 16.
Could be good or bad news for the Hobie Cat sailor. Time will tell.
well, maybe they'll continue the Hobby 16.More news on the transition:
Change is sometimes a good thing. – Hobie Class Association of North America
hcana.hobieclass.com
