JBOATTROUBLEMAKER
- Thread starter
- #21
I may change course for the same reasons, we will see...I had thought about that but ended up going paint due to cost and prep. Anyway, I look forward to following your progress! Enjoy!
Yeah - that last part is what finally swung me. That plus trying to maintain the texture on the no-slip sections with gelcoat, etc. It was just too much work. 6 years in, I've been absolutely blown away by the finish and durability of this paint though...My experience with paint and gelcoat is that the prep for both is significant, and similar. Applying by spraying effort similar for both. Paint more sensitive to contamination. Finishing effort higher for gelcoat as you sand and polish much more than paint.
Would white paint provide as much protection as Gelcoat?Yeah - that last part is what finally swung me. That plus trying to maintain the texture on the no-slip sections with gelcoat, etc. It was just too much work. 6 years in, I've been absolutely blown away by the finish and durability of this paint though...
Though I can't say for sure - It definitely depends on the paint (color doesn't matter I don't think). Obviously paint is thinner than gelcoat, but this Interlux has been super tough (rubbing up against docks, scraping on rocks and sand). I have zero complaints and would do it again in a heartbeat.Would white paint provide as much protection as Gelcoat?
Yep, even the pros will avoid repainting with gelcoat given the option.Forget gel coat. Sooo much extra work.
Just asked to prep and paint a Hobie yesterday. Faded blue hull with no decals left to remove with a heat gun and razor blade. Wanted to paint it to match the gelcoat. It looks like it just needs a good buffing with a wool bonnet and gelcoat buffing compound and that will make for an easy restoration.Yep, even the pros will avoid repainting with gelcoat given the option.
Thanks. Yeah, decks are flexy, like the thin foam core just crumbled. Hulls seem fine but I assume they are solid, if thin, laminate.Should check out beachcats.com, lots of experience over there. If you drill holes for epoxy injection, use a drill stop to limit hole depth, because you only want to go thru the top glass layer and the foam inside, NOT the inner layer of glass.
the gel coat is a lot more forgiving dragging the boat across the beach.....If you keep it insides Brightsides one part paint will stay glossy. Outside, not so much after 2 years. Paint with a 2 part polyurethane. Forget gel coat. Sooo much extra work.
Believe it or not, this H16 has no soft spots, main reason I bought it, only $350 too (with a trailer) and test sailed it before I drove it home.I have a prindle 15 that needs this treatment. Going to put it on the trailer today to get it out from under a tree. How are your decks? Mine are soft. Is that something I can live with or will the boat explode out from under me the first time I try to sail it?
