Sail4beer
Usual suspect
Nope!
DoRag looks sexy in a helmet. I'll say hi.It’s threads like this when I miss DoRag. Would love to hear his thoughts on being mandated to wear helmets all the time. It’s inevitable. It’s just what the nanny state of US Sailing does. Might take a while, but sooner or later wearing helmets will be a requirement to race. It will start with juniors.
I take it you've never been running deep in a dinghy or small boat when getting hit by >30º shift. Very easy to get taken out by the boom.Sailing isn't skateboarding - if you understand your vehicle and the conditions, there should basically be no situation in which you get concussed barring freak accidents. Or just sail a snipe without a whisker pole.
It is. But if conditions are like that you shouldn't be close to ddw as an autogybe wil certainly turn into a broach earning you a hit to the head and being dumped into the water face first with loose lines in the water on top of you. A new sailor will not have that instinct so your point is taken.I take it you've never been running deep in a dinghy or small boat when getting hit by >30º shift. Very easy to get taken out by the boom.
Sounds like a reaction time issue or a case of not looking behind at incoming squalls. I sailed at variable, unpredictable dinghy venues for 15 years and was never seriously hitI take it you've never been running deep in a dinghy or small boat when getting hit by >30º shift. Very easy to get taken out by the boom.
Research show the "not serious hits" are often worse than people self evaluate.Sounds like a reaction time issue or a case of not looking behind at incoming squalls. I sailed at variable, unpredictable dinghy venues for 15 years and was never seriously hit
Bang! that's a horrible sound. The guy had a bit on getting round the mark, maybe caused the brain fade coming into the gybe, some nearby shouting may have distracted him at the crucial moment, but damn, that's a horrible thing, that's someones biological computer inside the skull that made that doof noise. We may all be competent at ducking when we're head in the game, but information overload can creep up on us all, every accident has a chain of events leading up to it, sometimes happenstance can blunt our carefully honed instincts. Plus, in a big fleet, there's no saying that the boom or mast that gets you is attached to your own boat.This video link was posted in the DA discussion about the Finn boom incident that occurred in Brisbane. The incident is shown in the final 20-30 seconds of the video. Have a look (and listen) and see if that influences any thoughts on helmets.
Ronstan Finn International Championships Friday 13th 2023 video - RQTV
Ronstan Finn International Championships Friday 13th 2023 videorqtv.com.au
Last I looked I thought the Gath helmets were the best option that provided protection but minimized the risk of the helmet being so big it catches the boom when your bare head would not have done so, the sides taper a bit to reduce catching a mainsheet, and the straps are better thought out with clips and adjustments at the sides, not direclty under your chin like many brands. It is also one of the lightest.So, kayaking helmets are the way to go, if you don't want to pay WIP money? Any other options to look at? What brands are good? Looking for lowest profile possible.
DuckHow can we minimize head injuries due to boom / jibe impacts?
Helmets? – or padding on the boom?
not saying either are necessary - just looking at alternatives to helmets
The recent skull fracture in the cabo race got me to thinking – in that thread there was a call for helmets for offshore jibes – this has loads of problems, including cost , actually getting people to wear helmets, keeping the helmets handy, and not lost – then fitting them for various head sizes – and probably even more reasons
But I got to thinking – why not just pad the boom – the boom is the only real head injury issue – and 2 inches of foam inside a cover could work – it could be Velcroed on for installation & removal – only needs to cover the sides of the boom, and only from the companionway back to the aft end.
Maybe 10 -15 lbs tops – and if the mainsheet runs under the boom could be made as a mainsheet tunnel
Yes if you get hit by a padded flying boom you may still get a concussion, get launched overboard, or break your neck – but that would be the same with helmets.
The best part is it would be totally passive for the crew – they don’t need to do anything extra.
A concussion is way better than a skull fracture and a TBI
Not that I’m a big fan of lawsuits, but any class that doesn’t allow a way to secure the main sheet along the boom deserves to be sued. If it’s an international class, sue world sailing too. Neither can afford to defend monetarily or from a social perception.It is. But if conditions are like that you shouldn't be close to ddw as an autogybe wil certainly turn into a broach earning you a hit to the head and being dumped into the water face first with loose lines in the water on top of you. A new sailor will not have that instinct so your point is taken.
I think the issue is that current helmet designs create their own issues. None seem to be designed for a sailor on a boat with a very low boom with a mainsheet hanging 2-4cm below it. A good helmet could be made though. I keep looking at new helmets at the beginning of each season as I would like to have one. But not if it will catch the mainsheet on tacks and gybes and pull my head around with however much force it is carrying in that moment. I have the experience and dexterity to have that choice, I understand that some may not and the helmet may be a better option than going without. As I get older I'm really going to want that helmet.
Honestly this is one of those instances where OD rules are worse than useless. A few soft fairleads along the boom to keep the main snug to the boom with a mylar or dacron sleeve along the boom where I'm usually sitting in medium to strong breeze to make it impossible for me to become caught in the sheet, makes sense and makes the boat no faster, it's just safety. But several classes specifically make that modification illegal which is stupid because then a helmet would be a no-brainer.
