OILCOUNTRY
- 0
Recently Purchased a Bieker 3 with a CST14 mast. Is there anyone out there with a manual that they have put together through time that they would care to share.
Thanks
Thanks
Where are you and your boat located?Recently Purchased a Bieker 3 with a CST14 mast. Is there anyone out there with a manual that they have put together through time that they would care to share.
Thanks
Interesting. Our rake range tends to be from about 8.2m-8.05m. We are a mid-fleet boat though, so might not be the standard to look at.hi again
bottom of transom is is the the 90degree bend where the actual undside of the boat starts. you should measure right in the middle of the transom, maybe a bit to the side when there is the bubble where the rudder casette is fixed on.
here we orientate at around 8,08m rake, more wind we go a bit down to 8,05 and lighter winds up to 8,12. depends on crew weight.
cheers,
Eike GER 37
