I built a boat. Now I need to make rigging
ed h
122
Poole UK
I wanted a boat but dad just got me some wood and said build it yourself.
I did.
I put a windsurf sail on it but it needs two sails.
Can I put my pics on here of me building it and if I do can you tell me the best way to make the sails and fix it?
Colin
1
I did.
Do it! If this place has anything to offer it is a glut of people ready to tell you the best way to do anything!
ed h
122
Poole UK
I asked my Dad for all the things I wanted for my Birthday.
A lego car, a hotwheels kit, roller blades, a new computer, a lego police station, a lego train set, a lego airplane, a new bike....
...So Dad took me to B and Q and bought me a pile of wood.
I did.
From the truncated version of your post which appears on the Sailing Anarchy forum page - the way it displays on my computer anyway - I thought you had to find a solution for getting it out of the basement. :p It is possible to make a serviceable sail out of poly tarp; which I have read - in a possibly apocryphal account - is the no.1 sail material in the world due to the many third-world fishermen who rely on it.
ed h
122
Poole UK
4552.jpg I am cutting out bits of spine.
I had to rub some off because I missed the line.
Had to make this bit thinner. Tried hitting it with a hammer but it didnt work.
Time to screw the bits together.
Cutting out the round bits of this was hard
This thing doesnt tell you wether its going to try puting the screws in or taking them out.
Cant find the bolt hole
ed h
122
Poole UK
I am dripping the hardener into the resin to make the fibreglass work.
I need 3 drips for each 10ml. All the maths is hard.
Counting is easy though
I am cutting this to make the bottom the right shape and to keep water out of the front
I am measuring to make sure I get the back in the right place to keep the water out
I put fibreglass mat on this side and rubbed in the resin so it would go hard.
Dad decided to help by turning it over so I could do the other side.
As it hadnt set, it all fell off.
I think Dad should make his own boat.
Dad forgot to take a picture of the mess he made!
I am screwing it together ready for more fibreglass
ed h
122
Poole UK
I am shaving the bottom of the front until its flat
I am flattening it until its smooth like the palm of my hand so I can fix them together
Now its gone hard, I am fibreglassing it to the centreboard slot
I am waterproofing this as I made too much resin and dont want to waste it.
I taped the hog to the panels as well.
I will have to put more resin on it to make sure it doesnt leak.
Er...
I think I should have cut these to the right width before I fibreglassed them on
Dad always blames me, so its my turn
It was dads fault!
I am going to bend it until the front is the right shape
I put some clamps on to wrap stretchy rope around and used the jigsaw on the middle until it bent nearly all the way then left it for a couple of days so it could get used to it.
ed h
122
Poole UK
I had to cut a lot off the middle
Dad said "OI - Whats that doing in the kitchen?!"
I told him it was crying outside because it thought it was going to rain.
Dad wandered off muttering "but its a boat"
Now the nose is bent, I am taping the joint.
Its got to stop the water going in.
ed h
122
Poole UK
I am clamping it together so it wont fall off while it dries.
Its gone wrong!
The chines wont fit properly. I cut them the right width, but they wont go around the front properly and sit on the sides flat.
Dad said it was my fault for not measuring it properly.
I dont know what went wrrong - so it was Dads fault.
Dad said that if its his fault, he wont take us to Mc donalds
so we will let dad think its not his fault!
I had a really good look at another boat.
They looked straight on there.
I made a new wide one to try it.
It was better but still not right
I drew round the bits and took it apart.
I cut next to the line all the way up to where they go next to each other and then I cut on it.
I cut the bent bit out of one of the deck pieces.
Dad will grumble about getting more wood again when he finds out
The bottom was bending so I screwed a piece of timber along it to keep it flat while I got the side on.
I drilled little holes with the little drill
I put little cable ties through the holes to hold it on
Thats two done on each side
One more to go!
ed h
122
Poole UK
Er....
Doesnt fit
Dads fault !
Shouldnt have told dad it was his fault.
Trying to hold this in place with my head while I get the cable ties in.....
Its on!
ed h
122
Poole UK
Dad seems to think it will leak
Just making sure it feels right.
I have mixed microfibres into this so I can fill the grooves between the ties
Im filling the holes round the back
All dry
Time to take the ties off
The microfibres are all bumpy where I put them in with a stick.
Should have used a syringe
I am getting the last of the ties off
Ive got the tape on in here and painted the ply with resin
Putting the tape on this side now
Its going to rain and dad says its now too big to go in the kitchen
So we are going to build it a tent.
ed h
122
Poole UK
I need a strong bit here to stand on.
I am trying to bend this bit of wood but its not working
But thin wood will
This is a lot of strips I cut off the plywood boards
I am flattening the chines to make them the right shape
I am cleaning off all the bits after dad did the chines with the angle grinder.
Dad wont let me use the angle grinder as he says its dangerous.
They are a lot more flat now!
I am going to fibreglass the whole side in one go so it will be nice and waterproof.
Its gone wrong
I kept pushing it and it wouldnt go flat round the corners and it fell off.
Its got huge bubbles.
I dont think it will keep the water off.
Dads fault!
Took ages to scrape all the ruined stuff off the boat.
The man in the shop said the corners were probably too tight for the fibreglass mat to bend around. He said microfibres in the sharpest corners would help and how about using tape for the chines. He had some 10cm wide stuff.
I did the corners with microfibres.
I put them in with a syringe. You have to be very careful not to make lumps, so I didnt let dad near it.
The corners are less sharp now.
Its also a bit nicer.
ed h
122
Poole UK
Dad found out I have been mixing fibreglass with his favourite screwdriver
He is grumpy again
I am soooo pleased that it was dad who left the lid off the fibreglass resin tin and knocked it over and not me
The man in the shop said that the only way to get resin off is to wash it in acetone.
He also said you cant tip acetone in the washing machine or the bath.
Dad says he is going to throw his clothes away.
I think he will get very cold.
Time to fibreglass mat the bottom again.
I want it thick on here as it is going to get hit each time I crash and dont want to spend time fixing holes.
Its gone on much better this time
There are a few lumps but they will go when it gets sanded and if not it will help it grip the water better.
Time to do the chines again.
I have painted the side with resin and stretched the tape along it.
I am painting it again now
I can tape all the way round in one go.
If you lay the tape on and pull the top and bottom corners, it bends until it goes to the shape of the hull and doesnt leave any big gaps. I am overlapping the layers like you do bricks so it will be very strong.
I think its time to turn it over again
ed h
122
Poole UK
I am taping over the back of the centreboard slot to make sure the water doesnt flow inside. If it does its going to sink.
It has stopped raining again so I am starting to put my edge on
This has to be very strong so I coated the side of the boat and the strip with microfibres and clamped it on, then did the other side and another strip and clamped that over the top.
I had to stagger the joins as these arnt long enough and it really needs to be strong.
I also screwed them from inside the boat.
I will cut the end off later when its all nice and dry.
I have put the side tank sides in with clamps to see how much room will be there for me.
Cant wait to sail it!
I am taping in the side tank. I have to be very careful as it has some gaps under it and I dont want the tape to fall out.
Cutting this off while the tanks dry.
It rained.
THe bottom doesnt leak.
This is bendy wood
Im putting it together with microfibres
ed h
122
Poole UK
I am drawing where to cut the deck to fit
I am painting the edges ready to put it on
This is the wood to hold the back of the front deck
The mast will lean on this so its got to be good
I am marking the mast gap
Almost got it right
Got to take it off and paint the edges and under it.
Ive got the edge strip on now I need to get rid of all the lumps and splinters
I am painting the joints with fibreglass
ed h
122
Poole UK
Building the rudder is hard
Its heavy and there are no strips of metal to make it stronger
I think it will work but Dads not sure.
There isnt any nice wood left, so I had to use an old piece for the tiller.
I want to try it, so I will make it nicer later.
I am going to use my windsurf mast and sail to test it.
I am screwing a little table leg to the step so the mast can sit on it and not fall off.
The mast fits and all the ropes are on
Yippee!
The sail cant turn round far enough because my boom is hitting the shroud.
I will use a pole instead.
