i70s bricked or not?
sailman
436
Portsmouth, RI
 I am working on a friends boat and he is having issues with an i70s instrument.  During a software update the instrument was off and the download failed but now the instrument will not power up.  Any ideas?
phill_nz
953
internet atm
from ...
https://www.manualslib.com/manual/1253095/Raymarine-I70.html?page=1#manual
15.2 Power up troubleshooting
Problems at power up and their possible causes and solutions are described here.
Product does not turn on or keeps turning off
Possible causes
Blown fuse / tripped breaker
Poor / damaged / insecure power supply
cable / connections
Incorrect power connection
Power source insufficient
Product will not boot up (re-boot loop)
Possible causes
Power supply and connection
Software corruption
System checks and troubleshooting
Possible solutions
1.
Check condition of relevant fuses and breakers and connections, replace
if necessary (Refer to the Technical Specification section of your product's
installation instructions for fuse ratings.)
2.
If fuse keeps blowing check for cable damage, broken connector pins or
incorrect wiring.
1.
Check that the power cable connector is fully inserted into the unit and locked in
position.
2.
Check the power supply cable and connectors for signs of damage or corrosion,
replace if necessary.
3.
With the unit turned on, try flexing the power cable near to the display connector
to see if this causes the unit to re-boot/loose power, replace if necessary.
4.
Check the vessel's battery voltage, the condition of the battery terminals and
power supply cables, ensuring connections are secure, clean and free from
corrosion, replace if necessary.
5.
With the product under load, using a multi-meter, check for high voltage drop
across all connectors/fuses etc, replace if necessary.
The power supply may be wired incorrectly, ensure the installation instructions have
been followed.
With the product under load, using a multi-meter, check the power supply voltage as
close to the unit as possible to establish actual voltage when the current is flowing.
(Refer to the Technical Specification section of your product's installation instructions
for power supply requirements.)
Possible solutions
See possible solutions from 'Products does not turn on or keeps turning off' above.
1.
In the unlikely event that the products software has become corrupted please try
re-flashing the latest software from the Raymarine website.
2.
On display products, as a last resort, you can try to perform a 'Power on Reset',
however this will delete all settings/presets and user data (such as waypoints
and tracks) and revert the unit back to factory defaults
