Maybe... but from a first-principals standpoint, isn't a trimaran using air-filled "bulbs" for stability, rather than the lead filled keels of a monohull? And they are a lot faster.Mind you, to provide enough righting moment by buoyancy, you would need a huge bulb which would probably do more damage to speed than good.
Good point. but you do not stick one of the amas of a trimaran vertically under the keel and drag it fully submerged.Maybe... but from a first-principals standpoint, isn't a trimaran using air-filled "bulbs" for stability, rather than the lead filled keels of a monohull? And they are a lot faster.
I guess if they wanted to maximize boyancy it should be a vacuum in there!That must use special and hard to obtain 'High Flotation Air' in order to be effective.
That's looking like a sonar array going under a deep vee powerboat.![]()
Okay yes, it is a bulb keel. Is there anything more?
OFFS.
That's a tape drip line.it's off center so it's an articulating bulb, "with side scan sonar", on a power boat hull judging by the chine just above his head
