In water transducer repair question/advice
TheSDOtter
I am in the process of upgrading from an Airmar DT800 transducer to a new DST810. I thought that the retrofit would be easy and straightforward, but learned hard way that the old valve assembly/flap valve needs to be removed so that the new DST810 will fit. Has anyone attempted to remove the valve assembly from an Airmar transducer WHILE in the water? I figure that removal of the valve assembly needs to be done with Red Bull Formula One precision....and any complications could be very serious. Am I being a nervous Nelly and this is easy or should I wait until the next haul out.
What do you guys think?
See Level
Working to overcome my inner peace
3,119
1,491
Over there
Those flap valves won't stop water from coming in only keep you from getting a gusher in the face.
I'd recommend do a haul and hold in the travel lift slings at minimum.
Rain Man
2,496
Wet coast.
Get your diver to jam one of these in as you remove the old unit. Cheaper than a haul out. It can be tied to the toerail with a light string for easy retrieval later. Made by Forespar.
andykane
244
Victoria, BC
Or, pull a tarp over it. Should be able to position it with lines from on deck and it'll seal against the opening. I was surprised how effective it was when I had to replace a throughhull valve and couldn't get a haulout in time.
But get one of those foam stopper, just in case.
Bugsy
909
Canada
I have changed the paddlewheel on my speedo while in the water. For about three terrifying seconds there is a fountain of water spurting into the boat.
It looks worse than it is. The amount of water is perhaps a quart or two.
tane
352
mounted (& changed 2 days later because it was defective from start) a non-removable transducer, including drilling hole in aluminium hull in the water.
Key:
stainless saladbowl with flange+silicone on outside
PET-bottle with rag on inside
3 people:
one in dingi with snorkel
one inside drilling/sealing
one inside standby
(& plenty adrenaline...)
water entered: ~100ml
boat at anchor Fanny Bay, AUS, NT
changing just the transducer housing will be way easier
