INEOS Team GB
nav
671
Starting to look like they are coming to grips with it......bit chancy trying to cross in front of that cruising yacht though, good decision to bail
nav
671
With Leigh McMillan. Asked about the 'foil waxing' seen in the previous video and this one but he doesn't give an explanation
enigmatically2
2,690
Earth
I think it’s something to do with a bow up sailing mode that they keep using. If you were trying to initiate a very high mode and see at what point, the flow detaches from the top surface of the foil you could use a test like this
Possibly where on the foil it detaches rather than at what point
JALhazmat
1,932
Southampton
Keep applying it and at the point it stays there you know know isn’t or you can see it breaking up
as a team they have done alot of the bow up mode testing and always hard upwind, personally I think they are looking for a really hard up wind/high mode after getting done in the start box by LR who had the best high mode of all the teams
blending a high mode into a foil that’s raceable with a low stall speed yet fast enough. I think it’s where they’re heading
Forourselves
2,597
New Zealand
Its interesting listening to the commentary from the teams who designed their own LEQ12 and lined it up against the AC40 (LR and Ineos). The common theme was that the AC40 is lighter than the LEQ12. Given that the Version 3 AC75 will be a lot lighter than the version 2 AC75's, it may be interesting to see how those teams (LR and INOES) have scaled their LEQ12's. Whether they're scaled down from the previous AC75 class rule, or whether they're scaled from the the future AC75 class rule. If they've scaled down from the previous AC75 rule, and the AC40 is scaled down from the future AC75 rule, how that decision affects the data collection and how that data scales up to the new AC75.
When they started training on Te Rehutai again recently, ETNZ noticed the weight difference of Te Rehutai in her new configuration, being lighter, brought about new performance characteristics. Wonder if the AC40/ LEQ12 has given ETNZ the ability to scale those characteristics up more efficiently than the other teams.
Luna Rossa and ineos will surely have scaled their leq12s down from the model that their testing results have returned to, the v375, currently under build for most teams I think.
Alinghi and American Magic are in the same boat as us, so to speak, training in a v275 against a 40/leq12 combo with results again being driven towards the v3.
A prior point raised and a good one was which was the best way to go.
I feel the tboat path could yield the best results for the v3.
That said, I'm naturally conservative and more than happy with the Etnz way.
JALhazmat
1,932
Southampton
That the flow is detaching 2/3rd back from the leading edge
which on its own doesn’t tell anybody anything what you need to know is precisely what angle everything was set up, flap,arm, heel, angle to the wind and any other hundreds of variables
enigmatically2
2,690
Earth
I get that but because those will vary during the sailing I can't see how it would help
Though I guess with cameras they can tell when it comes off
Stingray~
4,407
from
The third session began with a self take-off before the team repeated the exercise of 'painting' the outer upper surface of the starboard foil wing that they did on their previous outing last Friday.
This time the 'paint' was a much darker colour – presumably easier for the foil cameras to spot.
It was applied by a fifth crew member on board just for this exercise. As during the previous session the foil would be painted, the crew would sail for a few hundred metres on starboard, then tack, sail bow up on port, and then stop to photograph the foil and reapply the paint.
This was repeated three times over a half and hour period.
enigmatically2
2,690
Earth
it sounds like they are following a set test pattern or something crazy like that?
Presumably with small variations in something. Though on the runs we could see I couldn't see much difference in the paint. Though they were photographing it so maybe in analysis they can pick up something important
Stingray~
4,407
That they are using 'VizFlow' paint seems smart but it also suggests they do not have pressure sensors across the foil wings. Maybe they do have some number of sensors, but want a more 'linear' reading?
JALhazmat
1,932
Southampton
I think what it actually illustrates, is that teams have a better idea of their testing schedule, methodology and regimen than the inhabitants of sailing anarchy.
the bow up trim has been a long standing feature of thier program on all three of the foils they have trialed so clearly they see merit in it as a test criteria to get them the performance they want.
