LordBooster
- 484
- Thread starter
- #4,201
A beauty!The Shadow had an extended length, double grip & ratcheting handle for the runners. I've never seen another.
Popeye, two-tonner designed by Bruce King, bilge boarder built in Sweden. Built in C-flex. Close sister to Aggressive
You are probably correct. Although King's bilgeboarders were short for their IOR rating. I want to say Aggressive II was 37' LOA, but may have been 39'. Memory fuzzy on that detail.Hmmm, doesn't look big enough to be a 2-tonner. Any additional info? LOA?
I've seen Barient ratchet handles, and custom shortened double grips.Stock Barient item back in the day? I know Barient had 18" doubles as a stock item. Don't know about racheting etended handles
Yeah. Terrorist was about 35.5 feet IIRC, so call it 5% shorter than a typical one-tonner of the day (37-38 feet).King's bilgeboarders were short for their IOR rating.
Found a short discussion about Popeye in a boatdesign.net thread starting at post 339: https://www.boatdesign.net/threads/old-quarter-tonners-magic-bus.24492/page-23Yeah. Terrorist was about 35.5 feet IIRC, so call it 5% shorter than a typical one-tonner of the day (37-38 feet).
If Aggressive II were the same proportions, I'd guess it to be about 39 feet (5% shorter than the typical 41-42 foot 2-tonner)
Or something.
I guess that could be a 39-footer in that photo (Popeye). The extreme beam of these bilgeboarder designs does tend to mess with the eye from that angle.
Aggressive II was 37 feet....Yeah. Terrorist was about 35.5 feet IIRC, so call it 5% shorter than a typical one-tonner of the day (37-38 feet).
Or something.
Martin King is Bruce's son. There was also Hawkeye which was a 48 footer.Found a short discussion about Popeye in a boatdesign.net thread starting at post 339: https://www.boatdesign.net/threads/old-quarter-tonners-magic-bus.24492/page-23
The posters confirm Popeye is a One ton.
In a side discussion it was indicated Marty King (must be a relative of Bruce King) said only one of the bilgeboard 2 Tonner was ever built - so if you found one, it would have to be Aggressive II,
I sailed on Hawkeye in Newport, RI and I don't recall the board lifts being hydraulic. I distincly remember them being Barient spinnaker pole butt-lift chain drives. At the start of the day, you had to wind the board down but they came up fairly easily. But they gradually filled with water and by the end of the day, it was a chore to lower them without them running away and a real bear to grind them up.Martin King is Bruce's son. There was also Hawkeye which was a 48 footer.
