• The Forum will be unavailable on March 27, 2023 from 8:AM to 12:00 PM EST for maintenance.
J/111 cross sheeting
JL92S
431
UK
Harken 57mm black magic Footblock mounted on the combing in front of the winch and then across
JL92S
431
UK
Amy pics of the setup?
No pics of our setup but here’s a GA and photo that I scribbled over showing where the foot blocks go 2EEC6F06-D6B9-4F32-9B8F-4AC742F622A1.jpeg 7EDD95C8-134D-4896-938A-F823F66BEA26.jpeg DCF27075-9EA3-4CB0-A76B-FDD6BF459C1C.jpeg
Monkey
2,851
Different boat, but pretty much the same concept. You can see the turning blocks right in front of the runner winches.
JMOD
111
Netherlands
you can also attach them on the stanchion on the side, going across. of, if you want to do it the fancy way, install a ropeye through deck loop and attach it there.
danstanford
183
Lake Ontario
The few times I have done this while sailing alone I ran the sheet around the leeward primary and up to the windward one. It made the tack a bit more challenging but I didn't have to worry about breaking gear when the load came on.
George Dewey
132
Charleston, SC
Is the deck area in front of the winch where these mount solid glass, or cored deck? Just want to know what I'm getting into before I drill. If its solid, it's a simple installation. If cored, not so much.
JL92S
431
UK
Honestly couldn’t tell you!
Goblew
6
Detroit Area
I put backing plates on mine just to be sure.  I cross sheet most of the time except for very light winds when jib trimmer is likely to be leeward for proper heel angle and better jib trim visibility anyway.
George Dewey
132
Charleston, SC
I was just checking for access Sunday. Good news is there is plenty of access, and most likely the deck there is solid, not cored. I planned to make some backing plates from some starboard or something.
I was thinking cross sheeting would probably be mostly a heavy air thing. When trimming from the high side, it seems the trimmer can't see the leach.
Roleur
783
Orcas Island
G10, not starboard.
Marks on the jib sheets make the cross-sheeting work better.
