I'm looking at a few of the j/120s on the market, and I see a couple that mention having the deck hardware bedded in epoxy and resealed, and others with moisture around the deck hardware. One survey noted moisture in the deck but recommended rebedding the deck hardware and not addressing the existing moisture.
I know buying a 25 year old boat I'm going to have maintenance issues, but how big an issue is moisture in the 120 deck? On my last boat with a balsa core, repairs became pretty extensive.
How easy is it to remove the headliner to get at the underside for repairs? I've replaced an engine and recored deck before, is this a project I want to leave to pros?
Are there other issues I should look for?
Is the 120 still a good, solid used boat? I'm just starting to look but there's not much I'm seeing that looks as well built/study yet still fast.
Thanks,
Kevin
Thanks,
Kevin
