j/29 j29 size/diameter of the upper and lower shrouds and forestay
MaartenSG
SG
Good Day,
We just got a J29 but the mast was without the right shrouds/stays. Because as we follow the trim guide the 6mm which where on it will be overloaded (>30% break strength). Could anybody help me out with the right diameters of the different shrouds/stays on a J29? If possible metric ;-)
Many thanks in advance.
longy
Overlord of Anarchy
6,757
1,126
San Diego
Masthead or fractional rigged?
I don't know the wire sizes, but this is the first question to ask.
Sisu3360
198
I may be off base, but from memory, masthead boats were rod and frac boats wire.  7/32nd seems to stand out for the wire boats.
I used to crew on a MHOB and I recall everything being wire, but it probably had been replaced since new.
longy
Overlord of Anarchy
6,757
1,126
San Diego
J - 29's had a lot of variance (at least here on the SoCal coast) depending on original pocketbooks. Rod was probably a stock option
Squalamax
87
My MH 29 has 1/4" uppers, lowers and forestay, compacted(dyform) rigging. 3/16" intermediates. Backstay is 1/4" dyneema.
It was the same size in the standard stranded wire before I replaced them.
