It's a bit stochastic. You can mitigate the risk of some level of wind (say gale force) but you can't get it down to zero on a significant passage. A front might cover most of an ocean basin and come ashore on a continent. If you're between them and realities of bars or politics don't favor you then there isn't a practical speed that will get you clear. With smaller systems you have the vagaries of forecasting. A tropical wave might develop a low level center or two anywhere in a wide area. Models might move their solution around a hundred miles in 3 hours. GFS and EC might well disagree. Far form shore the weather models sometimes go off on wild tangents (at least on the scales that 20 knots will make a difference on) and take quite some time to get corrected. A fast moving low might fly out of the topics or SO and the models might disagree wildly on where it's headed. Given enough time some wx forecast will be ambiguous and it will not be clear where to route. In the fullness of time you will see bad weather at sea. That said, the ability and willingness to motor for a day or two and decent wx info can make an enormous difference in the weather you will encounter and the time you will spend on passage. My WAG is that the ability to maintain 6 knots in any direction for 48 hours gets you a substantial majority of the advantage you'd get if you had 25 knots for the same period but every increase in speed and range should help.You guys have been talking about it so I'll throw it out there....is there an over/under in terms of boat speed and outrunning weather? I know the Dashews had it at about 10-12 knots. Not average, but boat speed in terms of outrunning in any direction under sail or power with large tanks. Based on how fast a weather system might move...opinions?
"in any direction"? There's a rub, eh? SV Delos has claimed 200 miles/day in their best conditions but apparently can't sail to windward well at all.You guys have been talking about it so I'll throw it out there....is there an over/under in terms of boat speed and outrunning weather? I know the Dashews had it at about 10-12 knots. Not average, but boat speed in terms of outrunning in any direction under sail or power with large tanks. Based on how fast a weather system might move...opinions?
Those are good links! I'm not in regular contact, but I can send her email via SSB WInlink (I don't have her satphone #). I will send her a short list of the synoptic chart URLs, and she should be able to request the image files via saildocs. I assume that she has the NOAA "Big list of worldwide WFAX transmissions", but will offer to send her that as well.If somebody (Valis?) is in contact with her they could draw her attention to the Chilean weather products.....
'Tues 5pm Another rain squall lies off to starboard affecting us... I was busy studying what weather information is available as we head further S towards Cape Horn and on...
Been busy exploring weather information again - a matter of requesting files to see what turns up - they don't always give what they seem to indicate. Saildocs is an excellent resource - I can request almost any file on the Internet so long as I have its correct URL - but, clearly, I can't follow any links given within it. So I'm looking at weather information available from French Polynesia, Australia and New Zealand for when I lose that available from NOAA (U.S.), which only goes down to 20S.'
Available here in low bandwidth if she has iridium or whatever
http://web.directemar.cl/met/jturno/indice/english.htm
Also available by good old fashioned fax from Valpo (CBV) and Punta Arenas (CBM)......
Details of skeds and frequencies on the NOAA wefax page....
http://www.nws.noaa.gov/os/marine/rfax.pdf
The list is a bit outdated but at 1100Z they broadcast an up-to-date sked.
Here is her reply:Those are good links! I'm not in regular contact, but I can send her email via SSB WInlink (I don't have her satphone #). I will send her a short list of the synoptic chart URLs, and she should be able to request the image files via saildocs. I assume that she has the NOAA "Big list of worldwide WFAX transmissions", but will offer to send her that as well.
I've found some sea ice charts and South Africa marine WX, and sent her the links. I also found an old schedule for Cape Naval WFAX, and sent her the text (same data as in the big NOAA worldwide WFAX schedule).Wonderful!
Thank you so much!!
Just gor MSLP and wind charts - just what I wanted.
Getting Drake Passage - not clear what that is...
Do they have any Ice Reports for Drake Passage (maybe that's what it is?)
Can you find out if Cape Naval is transmitting from Cape area in S.Africa?
They are MRCC for S. Atlantic region.
And are wxfaxes available from SA Met Service, similar to these Chilean ones?
Thanks for your help - really useful info - making good use of my Iridium airtime!
