smooth operater
I am in search of any laminating table surface experience. Been using horizontal formica for years and really have no problems with it. But at the same time I am interested in knowing what other options there may be.
I use a polyethylene folding table. Not 100% flat but enough so that flat molds don't need shims. 9' long and epoxy doesn't like to stick.I am in search of any laminating table surface experience. Been using horizontal formica for years and really have no problems with it. But at the same time I am interested in knowing what other options there may be.
Steel (thicker than, say 2,5 mm) works also fine, provided you'll be using peelply against the mold surface. Steel surface will be usable for many years provided that one uses proper mold release. However, steel is quite heavy, and there must be adequate support beneath it so that the surface will remain straight so if you are looking for a "portable solution" this might not be best option especially if the table should be a very large one. On the other hand, other table materials will not be very lightweight either if the table is going to be a large one and should last long time (ie robust and straight).I am in search of any laminating table surface experience. Been using horizontal formica for years and really have no problems with it. But at the same time I am interested in knowing what other options there may be.
I used a 36" interior door blank on saw horses and covered it ith 6 mil visiqueen. Worked wellI am in search of any laminating table surface experience. Been using horizontal formica for years and really have no problems with it. But at the same time I am interested in knowing what other options there may be.
