Lazy Jacks on a racing mainsail
Strimar
1
Has anyone come up with a simple lazy jack setup for a 30-35' sailboat with a 13' boom that does not compromise racing performance and is stowed out of the way when sailing/racing?
yoyo
347
As mid said - but if you must have them...
Thin dyneema with small ronstan skock blocks. When sailing, loosen them, gather and pull them forward to front of boom around the reefing hooks/carabiner/soft shackle or similar and tension everything. You end up with dyneema tight along boom and up/down back of mast. Deploy prior to dropping sail. You can also tuck them away when mainsail cover is installed without needing to modify cover. Depending on how you plan to cleat/tension the lazy jack tails you probably want a cover on that area of the dyneema.
slug zitski
1,624
worldwide
Internal lazy jacks are the best solution for a racer cruiser
Be carefull with lazy jack mainsail chafe at the boom ... fabric helps
Google class 40 boats pics for ideas or talk to s sailmaker
DDW
1,402
Just let them hang out. 3 mm dyneema lazyjacks will make your competitors think you aren't serious, allowing you to sneak by them, while not compromising performance an amount you can measure except perhaps at the Olympic class boat level.
steele
266
Land of the locks
This is what I use on my 35' racer/cruiser. I don't need the blocks, SS eyes on the dynema work fine. They are tensioned on small horn cleats on the mast with no covers on the line and no evidence of wear over 10 years. As long as the main is flaked well I don't deploy them leaving the dock or raising the sail, just when lowering.
Performance wise I would have to be a much better sailor to notice the penalty of lazyjacks. An acquaintance who is a very good sailor has done some research and he thinks we underestimate the drag of halyards and other lines perpendicular to the wind. Perhaps someone smarter than me can figure out the wind load of a 1/8" column of line tucked against the mast.
Fleetwood
125
Sydney, Oz
Same
PaulK
This is what we do.^^^^^^^
mathystuff
883
I'm to lazy to do the math, but the Cd of a circle is .47, which is way higher than a streamlined section. All the lines going up a mast on the outside are a significant amount of drag.
Does that mean your average sailor is going to note the added drag from lazyjacks? Probably not. But small improvements do add up.
  • Like
Reactions: Mid
PaulK
Topping lift to help hold the leech in check or am I missing something?
We're removing the topping lift for next season. It only chafes the sail and on occasion gets wrapped around the backstay. Since it's fixed at the top it's useless as a reserve main halyard or as a safety line for the bosun's chair. The rigid vang works fine to hold the boom up.
DDW
1,402
17 knots of wind is 1 psf dynamic pressure. A circular section has a varying Cd, depending on the critical Re, as much as 0.7, as little as 0.3. Something that small probably 0.7 as the Re will be low. On a 35' boat maybe you have 60' of line. So 60 x .125 / 12 * 1 * 0.7 = 0.44 lbs of drag @ 17 knots. Not nothing but not measurable on a boat even with very expensive equipment. The rig on a 35' boat has something like 175 lbs of aerodynamic drag. Would it actually be less if pulled against the mast? Maybe, but not nothing, either. If you are going for style points, then send then down or pull then against the mast. If you care only about speed, there are about 100 other things to pay attention to first.
Raz'r
6,370
De Nile
We use the reefing lines as a doubly duty lazyjack system. Drop sail a bit, snug the reefing line, do it again, now you’re dealing with only about 1/2 of the sail flopping around.
Haligonian Winterr
66
Halifax, NS
Also don't need the blocks/rings/thimbles on portions of the dyneema that don't move much. Ex. top of a bridle. Will reduce things that tap against mast/boom and annoy the shit out of you at night.
Zonker
7,478
Canada
Usually a cylinder is ~ 1.0 in air speeds we are considering
So 3mm rope x say 12m?
Cd = 1.0
Area = 0.003m x 12m = 0.036 m2
density air = 1.204 kg/m3
V = say upwind, 12 knots = about 6 m/s
Drag = 1/2 Cd A density V^2 = 1.0 x 0.036m2 x 1.204 kg/m3 x (6 m/s)^2 = ~0.78 N
If you have 2 of them that long + a few more short sections of rope, with blocks, and associated intersection drag etc - you're in the ballpark of 3N
Or roughly 0.1% of the resistance of a 30' sailboat sailing at 5 or 6 knots.
Loose clothing on the crew on the rail probably is worse. More lycra!
El Borracho
Barkeeper’s Friend
7,199
3,116
Pacific Rim
It is not so much the drag of the lazy jacks themselves. It is the philosophy they boldly reveal. Those lazy jacks plus the fifty other details excused with the same rationale certainly makes a noticeable difference in sailing speed.
Rather pointless they are, anyway, unless dropping the mainsail has a long history of spilling the cocktails.
dacapo
1,867
NY
Cd = 1.0
too many numbers. my head hertz
Strimar
1
ss eyes do you mean thimbles and do you have a picture or diagram of the setup?
