Nice haven't seen them before how high yo is your longest line off the back of the boom, guessing about the length of the boom?maybe the SS eyes referenced are sailmakers thimbles
Ronstan small shock blocks - no moving parts, simple and light.
There was me thinking the topping lift is a useful sail control line to enable the main to be scandalised.We're removing the topping lift for next season. It only chafes the sail and on occasion gets wrapped around the backstay. Since it's fixed at the top it's useless as a reserve main halyard or as a safety line for the bosun's chair. The rigid vang works fine to hold the boom up.
Pretty but too expensive for the job. Small thimbles are fine and cheap -that's what I used.maybe the SS eyes referenced are sailmakers thimbles
Just let them hang out. 3 mm dyneema lazyjacks will make your competitors think you aren't serious, allowing you to sneak by them, while not compromising performance an amount you can measure except perhaps at the Olympic class boat level.
Yes, that's what I used but I always took the lazy jacks down and tightened them against a hook at the front of the boom so they ran along the room when not being used. Since the cleat for the lazy jacks was on the mast it was simple to raise them again when reefing or taking the main down. My jacks were made in polypropylene dynena is a bit overkill IMHO. This was for a system without a boom bag.Building (rebuilding) a set of lazy jacks now. Using 1/8" dyneema. Want to confirm that SS Thimbles spliced into the lines are what folks are using. Would prefer not to go to rings to keep down chafe, noise, etc.
I believe I will have a 3 leg system with a full batten main.
For clarity:
Thimble:
Ring:
They have a boom bag so can't take the lazy jacks down. I'm cheap and don't like unnecessary chafe (my sails are not supplied by a sponsor and have to last more than one season). HTH
I made a set of lazy jacks last summer.Building (rebuilding) a set of lazy jacks now. Using 1/8" dyneema. Want to confirm that SS Thimbles spliced into the lines are what folks are using. Would prefer not to go to rings to keep down chafe, noise, etc.
For clarity:
Thimble:
Ring:
