Hi Zonker; yes I'm well aware of the intention of the oil installation here. But it's only a stopgap add on not well thought through. Also for a radial lip seal the reduction in differential pressure will only make the seal less effective.I think it is more likely to put a positive head on the oil in there to resist the hydrostatic pressure of seawater.
It's very common practice for seals like this on ships.
FKT; Yes open side down for both seals in this application on the HR (and note that you can get fully stainless seal components). If you really wanted an active pressurized oil dam as an active seal the the lower seal should be inverted......................
Second, and importantly, if the bottom seal *is* set in the position to best exclude seawater (open side down) then the spiral spring MUST be replaced with an O-ring. Those springs are not stainless and do not like exposure to salt water............
Sun is shining...I it's colder though. High pressure systems, it was raining more indoors this morning than it was yesterday.At least the sun is shining and it's wamer to-day.
If it is there may be strong words.Making the best of a bad situation BJ, sure it will work out.
My money is on the bottom seal being the wrong way round.
FWIW - not much - I think that's the correct decision. Painful, but correct.So I'm not going to fuck around with grease and stop gaps. I'm going to make arrangements to pull the boat next week down in Whangarei and drop the damned rudder and see what the hell is going on with that.
Doesn't matter. Flights are booked.FWIW - not much - I think that's the correct decision. Painful, but correct.
Hope it's something cheap & easy to fix.
FKT
Water coming into the boat from below.Thanks for the interesting blow by blow BJP. Very informative and I’m impressed by how seriously you take something I probably wouldn’t have noticed.
Boats! Who’d have ‘em?
Who said I could afford all this shit??If you can afford to pull the rudder out of a HR 50+ in a yard in NZ, where you sailed to, you are indeed living the dream...![]()
[First World problems
Ha! Yup, I know the feeling very well... Enjoy today, pay tomorrowWho said I could afford all this shit??h34r:
If I were just summering or coastal cruising, perhaps my decision making would be different. But then again, so would my choice of boat.Your decision is probably the most cautious, risk-averse and safety-oriented choice you could have made.
No one can or should criticize you for that.
Fair winds and safe travels.
Or the leak going around the back of the seal.Making the best of a bad situation BJ, sure it will work out.
