Yep, I would chase that F25C upwind and slowly be left behind but turn the corner and whoosh!Agreed, the multi 23 had many issues, the dyhedral, the horrible build quality of some, though I never broke my mast I did rip the aka out of the main hull, snapped the rudder and dropped the mast due to an improperly spliced shroud. But man, when grinding hard downwind those hulls are pure magic. Am I wrong to say you could buy 5+ nice beachcats for the price of one similar sized tri? And Multithom, have you tried a furling code 0 or top down system?
Yah, I converted to a top down system which does work better than the in luff torque rope (Hansen supplied torq rope was garbage). The "spin" isn't really a spin with 55% SMG (20% camber)...probably flatter than most code 0s but still made of nylon. The issue with time to set up, though, is the very long bowsprit that must be mounted while in the parking lot (like a beach cat). Then attaching sheets, furling line securing and lowering and securing to get out of the way--all takes time and typically a couple trips on and off the boat. Nimble is not my middle name.And Multithom, have you tried a furling code 0 or top down system?
There is a Multi23 listed in BAMA ratings (USA7; Flash) with a rating slower than my boat. Only reason I mention it is because I thought a multi 23 would be rated faster--especially given that the weight listed is only 50 pounds heavier than my boat. I suspect it is just a mistake, but maybe you know--can't imagine how that could be right unless it has a short stick.Yep, I would chase that F25C upwind and slowly be left behind but turn the corner and whoosh!
I think it is just a typo in the ratings list. The next boat down is also named Flash and is the same rating--an F242 rated at 69 which is the same listed rating for the Multi23.That multi 23 rating can't be right. Same boat rated minus 35ish in socal, mine was rated a few seconds slower. The one that surprised me is the f22. Why so slow? We have a newly arrived Pulse in my neighborhood. Seems nice, especially being able to keep mast up folded. Thom, can the searail do that? On my m23 and l7 I built short prods and found I can put a code 0 and reacher up there at the same time no problemo. I feel like the long prod might be a tiny bit faster but is somewhat overrated.
Yes. Install the mast raising lowering gear (just to keep the mast from rotating while you are gone, Tighten the shrouds (gotta do that to fold the boat to get on the trailer anyway), hook the main halyard to the mainsheet. Park the trailer. I suspect you can even hoist it to launch retrieve, but I'm not going to try.able to keep mast up folded. Thom, can the searail do that?
That's too bad, she was a bit cosmetically challenged with the faded red gelcoat, but I had her pretty bomb-proof (she was even @bhyde proof!). It was just a total PITA to figure out how to dry-sail it.It went to their house for a bit (though they don’t own a tow vehicle) and was listed on eBay. I was in contact trying to make a deal but they only had a small window of time they were available to sell (traveling elsewhere) and it didn’t work out. I couldn’t get a good feel for how much they actually wanted to sell the boat. Because of eBay’s policies I never got a means of truly contacting them, so I can’t offer any follow up. As of last September the boat was still in Ventura.
Yep, problem up here is no real good place to keep a double wide boat on a trailer.A guy came and buffed it all nice and shiny, looked very good. I felt like mine was relatively easy to move around on the trailer. I kept mine mast up and ready to go. It was like a wild pony at the dock and sailing it in tight quarters required lots of attention. Once out in the ocean it was very fun, except when it broke, which was often. The one named Flash seemed very well built though and the original owner, Jay, is a savage who pushed the boat to redline regularly.
I’ve found the Achilles heel of trailer sailing a 23’ tri is raising the mast. The L7 aluminum section? Heavy but strong. Did I mention heavy? Ours broke the raising system, did a header into blacktop. Broke the road surface and the mast. (Mundt wound up with the sails.) Replaced it with a rotating Gunter carbon wingmast (Forte). Hoping to try it out next summer when we get finally get moved to San Juan Island. Colligo, Spectra, flying jib, new daggerboard. The original daggerboard broke during the raising fiasco. Hoping the new lower mast (24’ and light, with diamonds) will prove easy to raise for trailer-sailing, and then raise the carbon topmast with the sail attached while in the water. A mountain gusty lake setup for the Salish Sea. Will it be stiff enough to control the leach? Expensive fun.......Yep, problem up here is no real good place to keep a double wide boat on a trailer.
Flash is the boat that I bought from Mike post Jay. Blew the rig out of her crashing off a wave. Hence the L7 section. Someone should drop a carbon stick in her.
That sounds nutty. I like it!I’ve found the Achilles heel of trailer sailing a 23’ tri is raising the mast. The L7 aluminum section? Heavy but strong. Did I mention heavy? Ours broke the raising system, did a header into blacktop. Broke the road surface and the mast. (Mundt wound up with the sails.) Replaced it with a rotating Gunter carbon wingmast (Forte). Hoping to try it out next summer when we get finally get moved to San Juan Island. Colligo, Spectra, flying jib, new daggerboard. The original daggerboard broke during the raising fiasco. Hoping the new lower mast (24’ and light, with diamonds) will prove easy to raise for trailer-sailing, and then raise the carbon topmast with the sail attached while in the water. A mountain gusty lake setup for the Salish Sea. Will it be stiff enough to control the leach? Expensive fun.......
