tane
- 352
...& do you know what "transom hung" is?
No problem. We will get a grant.Yeah you have to test if against a simulated whale. How much would a ballastic gel whale cost?
It's just gelatin powder and water. You might need a lot.
Clear Ballistics
www.clearballistics.com
One of the many things I like about my boat is that it will sail itself upwind and even on a close reach. But I was a complete failure at getting it to sail itself on a reach, let alone a broad reach.There's a bit in one of Tom's books about taking a new owner out on sea trials back when Tom built boats as well as designed them. He locked the rudder midships then put the boat on all points of sail using the sail trim alone.
Fucked if I can do that but I'm a shit sailor. I will say that my Witch tracks beautifully and requires minimal attention to steering; I can get it to balance under sail provided the wind stays constant (which is such a rare event here that it almost never happens). Even under power you only need to tweak the heading a spoke or less every few minutes.
FKT
Disclaimer - I am no expert on materials and structures.Bit of an aside, but as we start the process of the next cruising boat with the family, do you think Hawk, or aluminium production boats like the Boreal/Garcia/Bestevaer would have fared better in this type of whale strike?
Usually hull plating is sized for deflection, not so much strength. Fiberglass is likely to be around 2x aluminum thickness, to achieve near the same stiffness.
Maybe we can use a deceased beached whale as a plug for the mold? Also we could possibly calibrate and validate the first item synthetic whale against the deceased whale.Good thinking "Whale Injury Mitigation - Effects of Varied Hull Forms". Then whack it with bigger and bigger boats. That's got to be worth some serious cash. Should the whale be a big rectangle? Does it really need to be whale shaped?
We'd need a big mold. Perhaps a cylindrical whale? Borrow a fuel tanker truck that is due to be scrapped. This idea has promise.
I just assumed we'd be testing on Hunters and MacGregors?The problem, is finding sacrificial boats to test.
Dare say Walmart may have some folks who’d be interested in participating in a scientific study for your $10.We've found the ideal 'marine research' project for S/V Seeker. Next time a whale beaches off Pensacola (does that ever happen?), tow it out a mile or so & have Cap'n D ram the corpse with his indestructible metal boat.
I'll pay $10 to watch this experiment, which should behilariousinstructive whatever the outcome.
defrost chicken first
