Luff tape size on Furlex Roller Furler (200 TD)
soundsailer
Hi, does anyone know which luff tape size will fit a Furlex 200TD? Reason being I am thinking about buying a used sail. Hopeful the experts here may know, thanks!
accnick
2,974
I suggest you try the experts at Furlex. You might even find the information right on their website.
soundsailer
After some research here is the precise answer in case anyone searches this later:
#6 Luff tape works because its cord is 3/16th of an inch. This is small enough to fit into the 4/16th inch diameter slot (DLG in diagram below) but wider than the WLG (2/16th) so should not pull out (#5 won't work as it is too close 5/32 chord vs 4/32 WLG feel like a large risk of pulling out).
Table below is from the Selden manual...
