Luna Rossa Challenge. AC 36
Rushman
FIIGS
2,567
283
Melbourne, Aust
Are you looking at the right bit? The leeward foil? The one that is fully loaded? Under tonnes of pressure? If that is the play in the hydraulics the engineers need sacking.
I noticed the leeward foil “bouncing” on AM. Shot was from the bow camera of the starboard foil
Put it down to my eyes playing tricks but to watch more closely in the future
hoom
528
Orkland
That was why I suggested a while back that AM might have mounted theirs on some kind of suspension.
Could be the arm flexing though.
Horn Rock
1,807
Byron Bay
Sounds like on LR, the helm controls the traveler as well as the helm. That is very interesting to me! That's kind like sailing a singlehanded dinghy!
This is correct. Check out the stern cam feeds, you get a good idea of how they're doing things. LR have a simple but effective setup. Probably why their manoeuvers are solid.
bortolo
71
UK or Italy
Apologies if it was pointed out before but from the onboard radio it seems that the leeward helmsman takes over briefly when passing a top mark. To avoid the risk PB took of hitting the mark, I guess. Correct?
nav
634
It's in the lowered position and 'it' (the mount, the hull, the arm) is flexing under load.....nice
Indio
884
Auckland
He was referring to the raised arm in the particular video he referenced. If it's the lowered arm, it would be deliberate manipulation - listen carefully and you will hear the hydraulic pump hard at work.
nav
634
Eh? Are you at the right time stamp? Who would comment on a 'floppy' raised foil anyway?  :D
Lowered foil - no pump
Horn Rock
1,807
Byron Bay
It was good to see Jimmy front a couple of pressers. I love what he brings to these little talk fests. An interesting comment he made is that he is only seeing 50% of the race. From the stern cam audio he does sound a bit more subdued than normal. Himself and Bruni seem to be the only ones talking - in English as well.
Is 50% Jimmy going to be enough for the Handbags?
Zaal
699
Italy
Max on three ACWS days :
- Three very useful and interesting days. They lined up against the other 3 competitors in different wind conditions, so they could see what has to be improved, what is working fine and confirm the goodness of design choices.
- Next days they'll have a lot of technical debriefing in order to chose mods for the Prada Cup.
- They're not happy, because they lost the final race against ETNZ for the lack of breeze, and they could win the ACWS. Anyway performances improved a lot from Day 1, and that's the most important thing. The team stayed focused and ready to react.
- Prada Cup will be long and hard, every team will improve and there'll be a lot of mods on every Challenger boat
- Prada Cup winner will be a tough contender for ETNZ
- Every sailing hour is gold so now boat's in the shed, they have to do some mods, and then they'll be back in the water 23 December
- He wants to say thank you to all the team that worked 24/7 in these months (edit: this last point is from another interview he made 4 seconds after on another channel)
Zaal
699
Italy
Vasco Vascotto (off board tactician, sail design manager)  about DAY 2 (2 races vs AM, 1 win, 1 loss)
- Really happy about boat performance, they have some big modification coming up in the near future, so green light for him about this day
- The penalties were due to some difficulties in reading the course info. It's something that can be easily fixed, no rocket science.
- Really happy that the sailing plan made in the morning proved just fine. Right side had more current, and they went there when needed, and left side had more pressure at the beginning, so they went tin that direction at the start. Boat performance was really good.
Zaal
699
Italy
Speaking about mods, LR already  changed the rudder for the ACWS. But what are these red lines painted on the hull? Max in an interview said that they were going to do unusual things with B2, and that it was something that everyone will see. And talked also about "aero packages". So, what are these red lines, some "cut here" indications ?
This is an old pic by @mikenz2 if I remember correctly, just a few weeks after the spashing, right before a training session. It's easier to spot them while in the air, but this lines can be seen also in the other 2 @weta27 pics while sailing.
Any clue ?
buckdouger
410
Any clue ?
View attachment 416162 View attachment 416163 View attachment 416164
Thanks again for the translations! I wonder if they will shroud the crew like ETNZ.
Regarding the lines they seem maybe centered on the part of the hull with deepest draft. They also seem visible only from off the boat, so maybe a reference for the coaches to look at pitch and ride height?
Zaal
699
Italy
Francesco "Checco" Bruni  (one of the 2 LR helmsman) about the three ACWS sailing days :
- There are a lot of things to be improved, mostly upwind speed in the upper wind range. They're happy about boat performance in the mid-low wind range.
- There's a lot to be improved both in speed and moneuvers also in the medium/low wind range. They have to do an accurate analysis about these racing days, so that next time they go out they can test a lot of things.
- ETNZ has a speed edge in the upper wind range, mostly upwind but also downwind, but LR can perform a lot better also in those conditions, they just need to do a few adjustments.
- He thinks LR and AM speed is very even in the medium wind range, maybe LR is a little better in the low-mid and AM is a little better in the upper-mid, but the performances are really similar.
Zaal
699
Italy
On 12/19/2020 at 12:59 AM, Stingray~ said:
In Italian
Here the translation:
- He thinks that ETNZ has the best boat design. He likes the hull shape, the crew pods, the fairings on the arms, and their boomless setup.
- He thinks LR can improve "copying" the arm fairing and shielding the crew. He would also change the rake, since the boat is flying more even and less bow down than B1.
- He would prefer a one helmsman configuration on LR, with Spithill at the helm and Bruni calling tactics, in order to have helmsman, tactician and trimmer swapping side and using their weight to have more righting moment
- It's important to have a tactician on-board because Hauraki Gulf is a very shifty spot, it's really important to go in the right side of the course, and you can't have a tactician on-board with the 2 helmsman setup.
- he would add some coverinfg to LR grinders, like on Te Rehutai
- Right now Burling is the best helmsman in the world. Luca would like to have had the opportunity to challenge Burling, but with him (Luca) at the same age of the kiwi.
- Apparently he "parked" BA in a prestart (Edit: it's not clear when, Luca Devoti was the +39 Challenge helmsman in Valencia) and he was very angered. He thinks Ineos B2 is an "horrible shoe" but in the end maybe BA will fix it.
- He really likes AC75 concept, far better than the cats.
(Edit: I think the double helm configuration is really working, I have to disagree with Luca)
