13 minutes ago, bortolo said:
Yes, the rule is such that they can still "race" and do speed tests, it seems.I think they generally were at least 100m apart. The telephoto lens' being used makes it look closer- as well as harder to really tell relative performance
I wonder if I'm missing something, but aren't the running backstays implied as specified in the rig plan (is it publically available even?) and that alone means they can't be removed?maybe they will find a way to lower the main without sending a guy all the way to the top of the mast.
If that's the case, i think they pass the rule and would be able to sail without runners.
They may have to reinforce the base of the mast so that it doesnt fall forward somehow (when main down and no runner).
Just a wild guess.
Regards,
D.
What if they're not removed? Perhaps they just run down the back of the mast inside the twin mainsail skins. There is no weight saving, but there's a fair chunk of wind drag gone...I wonder if I'm missing something, but aren't the running backstays implied as specified in the rig plan (is it publically available even?) and that alone means they can't be removed?
This has already been addressed and ruled as non-compliant by interpretation #72.What if they're not removed? Perhaps they just run down the back of the mast inside the twin mainsail skins. There is no weight saving, but there's a fair chunk of wind drag gone...
Doesn't the rig plan specify where the chain plates are and that runners must be connected. Is your idea therefore that with a huge strop you keep them connected at both ends but there's tons of slack to route it through the skins still?There's nothing in interpretation/ruling 72 that prohibits the backstays being kept tucked away between the mainsail skins.
So long as the specified parts (dogbones, ferrule caps, strops and other specified parts) are used and the runners can be adjusted (that does not limit them being adjusted inside the mainsail skins), then it's fine.
Strops can be altered, moved or changed.
The ruling is largely centred around whether the runners have to be in-situ altogether (yes) and they have to be rigged so they can be 'adjusted'. Whether you choose to operate/adjust the runners is another thing altogether.
Play on Luna Rossa...
Exactly. Then you're class compliant.Doesn't the rig plan specify where the chain plates are and that runners must be connected. Is your idea therefore that with a huge strop you keep them connected at both ends but there's tons of slack to route it through the skins still?
