enigmatically2
If that were it they could just leave them there and apply minimal tension4) Mast bend flattens the camber up high too much.![]()
one can hope ..Could also be that the rear corners of the stern are structurally not built to support runner loads, so if their rig does not need them, and their structure does not even allow them to be used in the normal way, it's perfectly logical to try to find ways to hide them away aerodynamically
TrueWouldn't be the first time a team got blindsided by seemingly obvious rules...
Just kiddin!If that were it they could just leave them there and apply minimal tension
Sounds like there is a load test, so it seems the hull structure must be capable of at least some tension in them.one can hope ..
Sorry, should have realised you would know that. I'm still mentally scarred trying to debate with KateJust kiddin!
Big fat light air foils/rudder being asked to do tighter radius turns than they want to.just remembered that LR had several issues on the bear-aways on day 1. I don't think this was caused by the leeward runner, but I wonder if it might be evidence of them needing the crew for something else rather than easing runners (not that they have to be eased far).
But any ideas what LR's problems were?
Is the guy Carlo Borlenghi by any chance?think he is looking at the other foil ?
which side was their new foil on? Issues bearing away were all on port tack (so starboard foil)just remembered that LR had several issues on the bear-aways on day 1. I don't think this was caused by the leeward runner, but I wonder if it might be evidence of them needing the crew for something else rather than easing runners (not that they have to be eased far).
That's a profile I was experimenting with once but it's based on NACA64012What's the foil ID of that one? I've searched but haven't found any yet...
Wow. Coming to terms with something pretty bad. I guess all the teams are trying to get smaller on the foils front.Coming to terms with the new smaller foils?
