Mast shoe question - corrosion prevention
JoJo - SV Uku
1
Arizona
I've got a deck stepped mast. The aluminum mast slides into an aluminum shoe (think mortise and tenon), pretty standard setup.
I'm wondering if it would be prudent to coat the shoe with some Loctite LB8023 that I have on hand... Yay or nay?
I'm sure it isn't necessary but also figure out couldn't hurt. Or could it?
mgs
canoeman
1,216
300
maine
I wouldn’t do it. It’s aluminum on aluminum the corrosion will be from something else. That Loctite has some other metal in it and is a right bear to keep things clean.
El Borracho
Meaty Coloso
6,957
2,900
Pacific Rim
Well … @slug zitski and @mgs that LOCTITE 8024 has NO metal in it. (Ask me how I know) :)
As for helping the mast shoe? It might. Probably not. Apply monthly? Not likely.
Where aluminum fits tightly it is going to corrode because it wears, is wet, etc. Many boat parts are meant to be renewed after a few decades of service. A new shoe and a refreshed mast foot are not uncommon.
slug zitski
Banned
7,495
1,612
worldwide
I get in the habit of using tefgel on all metal mating surfaces …probably not needed
mgs
canoeman
1,216
300
maine
You expect me to read carefully?
El Borracho
Meaty Coloso
6,957
2,900
Pacific Rim
The ingredients of Loctite LB 8023 are listed in its MSDS.
Is there a chemist in the house to interpret it?
Tar, grease, soap, graphite and quicklime. Interesting. Graphite and aluminum are at opposite ends (bad) of the electrochemical series, right? That seems suspicious. But graphite is common in other goops. Quicklime is a voracious consumer of moisture. Like plaster. Whatever quicklime does in that concoction will be over in a few hours on a wet boat.
Complicated chemistry. I’d stick with lanolin or Tef-Gel. They seem more inert. Less active.
longy
Overlord of Anarchy
7,195
1,388
San Diego
First - make darn sure that water can drain from inside the mast. Second - once the mast is stepped, fill the crack between the spar & the base with silicone, get it as far into the joint as possible. Why silicone? it's waterproof, low strength, & does not conduct electrons.
Water & (especially) salt are what will cause corrosion
I watched a yard crane trying to pull the rig out of a Columbia 50 which had the same set up but down in the bilge (keel stepped). They had lifted the boat up a foot where the crane could not lift any more. They attacked the joint with a gas torch, they beat it with sledges. Finally they had to cut the mast just above the step cup.
slug zitski
Banned
7,495
1,612
worldwide
Hm
hmm
ive seen hoist issues with Spar tight
crane lifted the mast and the boat came out of the water
imbedding a “ cheese cutter “ cord into the pour ,to saw split the spartight Chocking , is standard , especially when the partner walls might form an upside down funnel shape
and water drainage at mast butts , steps is very important
drill another hole in the mast , mast step if you think it’s needed
as to the tefgel , locktiite, coating …before all these speciality products became available aluminum was protected with Lanolin
works well..
SloopJonB
13,892
Great Wet North
Something that hasn't been mentioned is to change the shoe from a cup the mast sits inside to a cruciform base that sits inside the mast.
I had to build a new step for my Columbia 43 and did it like this;
Due to the corrosion from the existing cup style step the foot of the mast needed to be trimmed to eliminate the corrosion so I increased the height of the new step block by a corresponding amount.
The alloy plate cruciform fits inside the tube and was scuppered in the corners to eliminate standing water. Much better than sitting inside a cup.
SloopJonB
13,892
Great Wet North
many layers of ply and glass mat laminated with epoxy.
Just for fun, here's what it replaced.
That mess actually kept the mast standing for a trip by the PO from Santa Monica to San Rafael.
kinardly
I’ve been told Sabre yachts of a certain vintage had a problem with poorly designed mast steps and drains that became plugged, leading to softening
of the timber support and wicking to the adjacent bulkhead. Can anyone tell me what years and models had this problem and can a correction be retrofitted? I’m looking at a couple of these and
I already rejected one.
AirisWindy
7
Not a direct answer to your question but I glanced at a 1988 sabre 38 that was an MK1, it "sold" previously but the buyers aborted the sale once the survey came back. If you look at the sole you can see quarter round trim. I do believe it was fully removed for the repair.
Its still for sale:
