MacaroniNBreeze
- 3
I just got an older (sub 100's) Melges 24, am trying to get her rigged, fix her up, and have no one around to ping questions at. I'm hoping I can get some questions answered that I can't find on the webs. The biggest obstacle in my path right now is the mast step bracket and the deck it is mounted on.
I tried to step the mast with a friend and on the first attempt we dropped it, nearly stopped my heart. I could go on about what we'll do differently next time... Luckily the mast and the spreaders are fine but we bent the starboard side of the mast step bracket. The starboard side hook flared up. So, I ordered a new one from Melges and to my surprise the new mast step bottom plate is completely flat while the old one has an angle to that matches the angle on the mast base rocker.
Is it normal to have this rocker angle in the mast step? Is this an example of the deck having been crushed under years of rig tension and I need to put in some G10 board? Or are there two types of mast steps? I've searched the web and I see a couple other mast steps that look like they also have an angle to them.
If this is a result of the deck crushing, is there an easy, let's just get the mast up, see how it holds rig tension, get the boat wet, and blast around solution?
Can I just fill in the angled dip in the deck under the mast with some fiberglass & epoxy? Seems like this wouldn't hurt a later proper G10 core replacement repair. Is this a terrible idea?
Are there any tutorials of how to put in G10 board under the mast step, if this is what I need to do?
Also, a little history on the boat: It still has the old white mast (Omuhundro?). The boat was updated in 2016 with new class certifications. Tons of little updates like sets of cam cleats on both sides of the traveler, jib ratchet carbon covers, class correct shortened stanchions, etc... There are no cracks around the stanchions, push pits look great, epoxy bottom paint. Someone clearly loved on it and it doesn't look like it was raced hard.
Thanks for any and all insight!
Old Mast Step showing how much the bottom plate is angled up. Looks like the deck has the same angle to it.
New Mast Step showing completely flat base.
