Meme Anarchy
Grande Mastere Dreade
Snag's spellchecker
Foreverslow
I thought it was worldwide.
Surgical forceps as a roach clip were the only thing superior as far as "repurposing" went and that was mostly because they were hard to get.
actually the best repurpose of foreceps was to remove and install disks of different thicknesses to take up valve lash on DOHC Suzukis.
Push down on a cheap specialty tool that levered the cam follower bucket and then use the forecep to remove the old disk easy peasy.
if you had a Kawasaki, you had to remove both cams and hoped you got the timing chain reinstalled correctly and no crud on the camshaft bearing surfaces else the motor was to to go BOOM! the first time you spun her up to red line..
Still have the foreceps, speciality tool and Suzuki 42 years later...
