MMSI and other transfers - new boat from Italy
1sailor
Importing a new to me TP52  from Italy which has a series of electronics that i'll need to register in the USA for safety and to meet NOR requirements for various distance events
We are dealing with a fixed mount VHF, a couple handheld VHF, an EasyTrax AIS unit, and a couple EPIRB units, including one I have from previous boat.
Could anyone direct me to a straightforward resource on these tasks, hopefully in bullet-point non wordy format so that my A.D.D. and C-student mindset can get thru this without counseling please ?
slug zitski
803
worldwide
Don’t know how they do it in the  US
I take the equipment to a licensed   GMDSS  technician
he reprograms the MMSI number , does a test transmission then  issues a certificate
on some equipment you can change the mmsi by entering the service protocol menu of the equipment and changing it
contact the equipment manufacturer for guidance
Wemedge
14
Detroit
You can obtain a new MMSI through the US Power Squadron website. Entering it into your equipment is easy enough following manufacturer instructions, however some devices will require a previously issued number to be cleared by the manufacturer or a service shop.
longy
Overlord of Anarchy
6,259
883
San Diego
Getting a new number is the easy part. Each piece of electronics will have different methods to change number. Some can be done with a computer/program attached, some have to go back to national importer.  EPIRBS are permanently coded to country of original sale!! They send message to that countries emergency center, which must then contact the country where the signal originates. Adds time/complexity to the process. Better off buying new units locally.
slug zitski
803
worldwide
Yes indeed
many times Epirbs get cancelled , then destroyed and replaced
your electronic shop can advise
as far as I know European  equipment is blank off the shelf then programmed to the individual boat with numbers supplied by the flag state
Seems  American equipment is pre programmed the you register this mmsi  to your boat
best ask
longy
Overlord of Anarchy
6,259
883
San Diego
MMSI is individual to boat, programmed by initial buyer. The country code is internal and not changeable. The unit will still work with a new MMSI, but response a bit slower as report gets shuttled around rescue centers.
slug zitski
803
worldwide
I don’t know , I always send the equipment off
https://www.marinepanservice.com/en/glossario/programmazione-epirb
i do know that mmsi numbers are in short supply and must be recycled
The old number…previous flag state must be cancelled and a new number from your new flag state must be used
longy
Overlord of Anarchy
6,259
883
San Diego
Read the 2nd to last paragraph of your first post - and 2nd para of your 2nd post. Both clearly state that units are hard coded to a country specific rescue center.
seaker
43
Maine
Only if you are not going to go to other countries. The USPS number is only valid in the US.
