MOD 70 vs. ORMA 60 - what's next?
The "Pure Multihull Porn from the mythic front page"  thread and videoos were excellent and got me thinking about the evolution of these big boat classes
The ORMA (Ocean Racing Multihiull Association) was a official racing rule propagated by the ISAF  (now "World Sail") in 1996 and active until 2007.   So, sort of like an oversized Formula 18.      The  MOD 70 (Multihull One Design) was created in 2009, and claimed to serve as the successor.
These were already a very different thing (Development Rule class vs. One Design class).    How successful were they?
According to Wikipedia the class:
"suffered many failures at sea, including capsize.[2] In one famous race, 2002 Route du Rhum, only 3 of 18 starters managed to complete the race. This eventually led to the abandonment of the class by sponsors."
The one design Mod70 was created to continue the heritage of large blue water racing multihulls, while addressing the issues that had arisen with the ORMA 60 designs.
MOD 70 said there was a "strict quota" of 12 boats, and seven were built.  Looking at the site it doesn't seem like the whole series racing idea ever really took off.   According to there web site 5 boats raced in 2012, and since then it looks like individual boats have entered a few races under open rules.  The One Design series racing thing never really took off,
I  don't know how any ORMA 60's were built, but it seems more than 7 - which seems to be the most claimed by Mod 70.   So, despite the supposed danger of the 60's it seems like it was the more successful class.   MOD 70 claims these design advancements:
SECURITY – RELIABILITY – PERFORMANCE
  • 1) Smaller sail area (5%) providing more safety when ocean sailing 2
  • 2) Longer central hull (10 ft) to minimise pitchpoling 3
  • 3) Raised beam clearance to reduce wave impacts 4
  • 4) Possibility to lift the centre hull rudder
  • 5) Curved foils for more performance and safety 6
  • 6) Shorter monolithic canting mast (+/- 8%) positioned further aft in the hull 7
  • 7) Low temperature cured carbon fibre & foam sandwich construction
So is the 70 the better boat, as the designers claim?   Obviously "bigger is faster", but the 60's had the longer mast.
  • There was no requirement in ORMA that all three hulls on the ORMA boats be the same length - if "long in the middle" were faster anyone could have built one that way.  (And in fact ORMA permitted cats as well as tris, I believe)
  • Obviously raised beams, curved boards, lifting rudders make sense.  Some later ORMA boats had  some of these features, and I don't believe  the rules prohibited any of them.
  • The beam on the shorter ORMA was wider than that on the longer MOD 70.   From the MOD 70 site: Measuring over 10 feet in length (21.20 metres instead of 18.28 metres), the MOD 70s are less beamy than their ORMA ancestors, the latter reaching 18 metres.;
    :But- ORMA had a max beam, and most builders took advantage of it, but it wasn't required to build to the max permitted.  A 60x40' boat was rule legal.   Is there some new consensus on ideal beam for a trimaran now?
So, which was the better boat?     The formula 60s seemed to result in a bigger field.  And the boats (the newest being over a decade old at this point) are still winning in head-to-head races against the supposedly superior MOD 70 and setting point-to-point records, like Mighty Merlot.
The supposed danger of the ORMA 60s seems based on one race, which was a tough race.  It was a long single-handed race.  It's may be easier to gut extreme weather out without worrying about capsize, so naturally most of the big multihull competitors chose to "abandon" as the French site on the race says.   So did 5 of 17 sixty-foot monohulls, though.   I don't know how many of the boats actually capsized or were destroyed in the race, perhaps a couple.
Was the MOD 70 a detour that has turned into a dead-end for ocean going multis?  Should the ORMA rule be revived, modified or replaced with a new rule that allows multiple builders and new innovation into this space?   Isn't a development class for multis of this size and cost inherently more interesting, and doesn't history prove that at this point?  Clearly we had not hit the apex of multihull design in 2009, where we pretty much knew everything interesting about how to build an ocean going multi. (Which one would be hard pressed to even claim for a more traditional monohull ocean racing category today).
ORMA 60 shot by Tim Feak Photography.
Notes:
https://en.wikipedia.org/wiki/ORMA_60
https://en.wikipedia.org/wiki/MOD_70
http://www.multionedesign.com/en/
https://www.sailingworld.com/sailboats/mod-squad/
Orma 60s are amazing tris in the right hands
I believe the MOD 70 was simply the next progression from all their extensive orma 60 experience,  and a one-design (MOD 70) was used to keep the build costs down and the fleet equally matched.
I've never sailed on either, but I would be pretty comfortable saying that a MOD 70 is a quicker design.
The next progression would probably be Gitana 17.
boardhead
As I recall - please correct me if you remember otherwise - the Mod 70 was created in an effort to revive ORMA 60 which had run out of steam largely due to escalating costs and, from a spectators standpoint, the utter dominance of Frank Cammas turning the racing into a procession.
Open classes yield much more rapid development, within simple constraints to discourage the dominence of size and money.
The simple box rule of ORMA 60 did give us an era of truly amazing boats and sailers who greatly refined the art whilst pushing the envelope to their destruction  - that Route du Rhum being a real wake up.
On a few points -
The 70 foot length was just a way to eliminate the sprit, same ama length.
The curved, lifting, ama foil made for safer, short handed power reaching rather than placing more volume in the ama bows with the more destructive platform loading that creates.
Everyone laughed at Geants stearing station windshields before she won, demonstrating the importance of preserving crew performance.
The Route du Rhum disaster led to the control of the use of high modulus carbon with it's high cost and lack of shock absorbing toughness.
MultiThom
394
Benicia, CA
To answer "what's next" you need to ask why folks want to spend lots of money on untried designs, hire professional crews, and risk lives for an entertainment.  Similar to those folks who race cars, climb high mountains, or other thrills.  Boredom?  Notoriety?  Nice that there are folks like that in the world so we can watch.
EarthBM
Even though ORMA was "development", the box rule was 60x60x100. This lead to a suboptimal outcome. A 60x60 tri can be powered up more compared to a 60x40 tri, so of course everyone coalesced on the max 60x60 dimension. So a random square box became reality, no "development" or "optimization". And so these over-square tris ended up pitch-poling. Then MOD 70 configuration was selected to fix this, which was "optimal" to the extent that VPLP designed it with a 70x55 dimension.
Giving more degrees of freedom, for example constraining the sum of beam+LOA at 125 would lead to experimentation and empirical discovery of the truly optimal configuration. Or perhaps constrain the total of beam + each hull length individually and you discover that proas are in fact faster/better. But this would involve high risk for the players of spending $10m on something suboptimal.
That's why I think The Race was the most successful/valuable modern racing endeavor. Can something like this be puled off again, or are the "wallets" too wise to be lured into this now? I don't know.
The ultimate practical question that most of us are trying to answer is "what's the best boat for my $$$?"
So I think a race designed with a fixed budget (via claiming rule) would be the most valuable.
eastern motors
153
The MOD70 design was owned by one guy and each boat was sold for incrementally more.  Something like 1-3 $2.5mm, 4-6 $3mm, 7-9 $3.5mm.  So not surprising that a ton weren't built.  I think Ocean racing multis could make a come back if a bunch of IMOCAs break their foils in the VG.
boardhead
Tough to pitch pole upwind and the OSTAR was certainly influential on ORMA development - greater beam spells higher RM for a given weight and the 18 knot upwind @ 90 degree angle was real. Center hull length is somewhat irrelevant to diagonal stability in anything but mass. Square trimarans are more appropriate in smaller sizes, in bigger boats the increased mass delivers RM with relatively lower beam.
So the boats can only be optimized for a given purpose - beyond the box rule - for ORMA I recall the limited sprit length and provision of an inboard engine were required  after Olivier Moussy was lost in the Quebec- St Malo.
The Race in 2000 saw no trimarans, all catamarans and probably represented their swansong in that down wind sleigh ride. Team Philips was the innovative member of that race but sadly never made the start due to a massive structural fail.
ORMA was inshore, offshore, single, shorthanded and fully crewed and rhe boats delivered all round!
French corporate spending and national pride had a huge influence on multihull development from 1966 to the present so what is the meal ticket for the future?
My enjoyment and involvement lay in the private owner/builder era which involved smaller but equally exciting multihulls - will that path revive - probably not.
Fat Point Jack
346
I bought a The Race t-shirt.  My wife saw the bill and it read 100.  She asked why I spent a 100 bucks on a shirt.  I said read more carefully, that is French Francs.
Thanks for this detailed answer.  I'm really interested in this.   Your use of the term "over-square" seems to suggest that there is an optimum ratio of length to beam for tris, and it's less than 1:1.
I don't understand why an "over-square" tri would be more likely to pitchpole.   Aren't the shape of the bows, the buoyancy of the bows and the front-to-rear weight (balance) of the boat the things that designers tweak to counter tendency to capsize?    I get that making the bows longer helps prevent capsize.  As I recall from the mega-cat era Playstation added 20 feet to the bows to fight pitchpoling prior to her circumnavigation record setting run.
Is perhaps the real problem that the extra beam gives the ability to overpower and not capsize,  but then extra length is needed to prevent capsize?   Would that make the "ideal" ratio the one where the risk of capsize and the risk of pitchpole are equalized?
Wikipedia:
PlayStation was originally launched with hulls of 105 feet (32 m) and was lengthened to 125 feet (38 m) LOA in August 2000, to minimize pitching. At 105 feet (32 m) PlayStation was overpowered and the possibility of a pitch pole in a yacht this size warranted the refit. Maximum beam remains at 60 feet
Besides increasing the length and decreasing the beam on the MOD 70s they also decreased the sail area, decreased the length of the mast, and moved the mast further aft on the hull (per my quote from their website in OP).
This is from 2013, and it's really awesome to see the entire fleet in a couple of the shots here.
Here is IDEC Sport, the current record-holder for crewed circumnavigation. (she's had a bunch of names).
So has Playstation, and she was named Cheyenne when she set the 'round-the-world record.
A comparison of two champion record setting boats - 15 years apart:
                                 Length              Beam        Displacement       Mast Height       Sail Area          Crew     Record                         Date
IDEC                        103'                     74'            18 long tons           131'                   8,910 sq ft           10            40d 23h 30m            2017 - Jan
Playstation             124'                    60'             27 long tons           135'                 11,150 sq ft           12           58d 09h 32m            2004 -  Apr
Gitana 17 is awesome, and basically is using the same architecture as IDEC Sport, but adding foils.  What an amazing machine.
They are currently on standby for their round-the-world record attempt, waiting for the right weather to set sail.   It's impressive that they seem to have a very small crew: only 5.    So, while we are waiting for the first full foiling record, it's interesting to look back at all the progress made against this record in the last 30 years.
The baton was passed from the cats to the tris in 2010.   From 1993 to 2010 six boats held the record, five catamarans and only one triarman.   (The last of the group was Orange II, which was dimensionally very similar to Playstation:  121' long, 60' wide.
Since 2010 three boats have held the record, all of them are tris.
What changed?  Clearly materials have changed.   A huge difference between Playstation and IDEC is weight. 27 for the cat, 18 for the tri.
EarthBM
Exactly!
The trouble is that these probabilities are hard to estimate accurately, so for discovering empirical truth you need a class rule allowing different ratios while keeping the overall power constant. Like fixing the beam+LOA=constant. Or even better: Beam+LOAama1+LOAama2+LOAmain=constant.
Besides increasing the length and decreasing the beam on the MOD 70s they also decreased the sail area, decreased the length of the mast...
Yep, need an overall constraint on risk. Or the winner-take-all mentality will overtake any remaining seamanship. Like people advising D35s (a toy boat for Swiss lakes) for R2AK.
EarthBM
And I’d really like to see a mandatory self-righting system. It’s not hard — an airbag at the top of the mast, canting mast. It just requires over-building the standing rigging chain plates and the like to take the impact.
I'm not sure the sail area comparisons in my little chart above are apples to apples.
On some of the other articles about maxi-cats they list upwind and downwind sail area, when neither is specified one wonders which it is.
Mast height is a decent proxy.
It sees like the shorter (LOA) and wider tris are faster than then cats which have the same size mast.    That's a rough generalization.
Maybe their are material issues, but it seems like a 100' cat with a 75 or larger beam would be more competitive with the trimarans.
I'd hate to be on the center hull 30+ feet in the air when the boat flips itself upright.. It wouldn't be easy grinding the mast running backs to flip the boat upright when the cockpit is almost upside down and over 3 stories above the water.
Trovão
to be strong enough it would be way too heavy. beams in excess of the 2x1 proportion, specially on a cat the size you propose, don't seem very feasible imho.
