ryley
I'll upload some pictures in a while, but it was essentially a matter of taking off all the electricals, disconnecting the fuel lines and the water line (with the valve closed obviously) and 6 bolts around the saildrive housing. I had to pull the alternator to get at the starter wires. There was enough play in the engine mount studs to be able to slip the engine off the saildrive spline. We used a 4:1 cascade around the boom to lift the engine, then slide it aft past the lifelines, and then out over the dock onto a tarp. we were able to carry the engine up to the car on the tarp - it weighs around 150 lbs.So I really could replace my motor mounts myself… How'd you pull it??? Pix?
