Wow- looking at the cert, that "I" measurement is 9' higher than original Southern Spars config... Like I said, this will be a beast in the light but she'll get overpowered prematurely with that setup. 95- Hope you have a lot of friends that want to go sailing.If your boat is the former "Pi," it rated 60 in ECSA in 2014. In contrast my Columbia 32 rated 75, but we've got the ballenger aluminum spar and fractional jib.
Jack Orr from North did a lot of work with that boat. You definitely need to find the runners. Jack showed me pictures from around 2014 of that rig inverted with a J1 or J2 up... owner was complaining about the fact that he couldn't sail it to the rating. You've got an outboard too if I remember so you've ditched the weight of the 1GM10 (as did eXigent). Personally I like pressing the button and not having to shlub around an outboard when I'm delivering the boat but you're obviously cool with it if you bought it![]()
the hatch drains, as I14 pointed out, are crucial, as is keeping them clear. high quality gasket material is also a must.
I'm not sure if yours has the carbon blade keel or the ductile iron. If it's the iron one, you'll need to check every year that you didn't cut through the fairing material with a crab pot line. The keel on my boat has been problematic, with delamination and a piss poor repair job. PO had it on a hydro lift and would motor in with the keel up, banging around in the trunk, thing was a mess. Don't do that - the boat's not meant to move with the keel up unless you can wedge it and keep it from swinging around. Feel free to PM if you have any questions.
here's a link to the last cert it had that I'm aware of. http://join.ecsa.net/cert2014.aspx?b=3854
It would be nice to try with a used masthead sym kite. The boat needs about roughly 16 knots to get on the step downwind. Anything less and you could be poling back like a big 5o5.I14, my C30-2 was definitely rigged for a symmetrical. track on the mast with ring, a fitting on the foredeck for the foreguy... but by the time I bought it none of the moving bits were with the boat - no pole, no sym chute. I think it must have had the symmetric when it was on Lake Lanier, but might not have been as effective as they hoped.
Thanks for the offer - I'll definitely take you up on it. We're coming from a Beneteau 10r, so it's quite different from that. Prior to that though we had a Melges 24 and then an Antrim 27, so this boat isn't unfamiliar.95Terp, I don't know what boat you're coming from, but if you have any questions about getting up to speed on this thing, I'm happy to help.
And yes, that kite was big.. too big actually. I have new North A2 that is slightly smaller but a better shape - if you look at the video, our luff is too long and it's hard to control the curl. New one should be sportier.
