martin 'hoff
- Thread starter
- #201
We learned a ton, and we had a ball!How did you make out at Nationals? What did you come away with learning wise?
Yes not much chance Nacra is going to make a big effort at this point to give us raking rudders unless the class goes fully foiling and I guess there is not a push at the N15 grass roots level to go that direction because of safety issues? Have started to draw something out, definitely looks workable ... will send you something across in a week or so
Mostly solo sailing lately, finally got the nerve up to hoist the spinnaker in more than 12 knts ... not as bad as I thought it would be, definitely more stable with the spin than with just the jib
We finished 11th of 15. Lots of gear trouble - cost us enough points that we think we'd be 8th (on back of the envelope numbers w the DNFs and considering our finishes in the completed races). And the wind turned up for the races (11-18kt with big and choppy swells) – but we had not seen wind for 3 months so we were rusty as f...
Quick random mix of notes
- When switching from Z boards to C boards, there's 8 holes you must plug. If you don't, you may find many many gallons if water in your hull. In a fit of fury, I put a dab or gflex.
- We also had badly leaking footstraps. Lots. Of. Water. Cured all water intakes by end of the regatta, but cost us performance in 8 of 10 races.
- We're off the pace upwind
- Upwind performance in 11-18 with pulsating wind demands helm active on cunningham - which works best with 16:1 (which we don't have)
- Boat has a fantastic groove upwind - hard to find, even harder to keep in choppy-gusty, but amazing when you find it and can keep it going for a good stretch
- We lacked practice in wind+chop - last 3 months no wind
- Lots of work refining takeups for various things, continuous cunno, jib, and cunningham-to-trap-handle. All these are amazing when they are just-so, and a headache when it's almost-but-not-100%-right.
- We were using Ronstan orbit 55 autoratcheting, but it doesn't ease promptly enough for fast gybes. Switched to harken.
- Moved the skipper trapeze bungee just a bit aft for easier crew in/out moves when skipper stays sitting.
- We're fast downwind, and took 2-3 boats on almost every downwind but
- was hard to stay in the groove in massive short swell
- crew (me!) was slow in maneuvers - time from sail-is-up to locked-on-footstrap, toggled-down, go-full-power was too long - same on gybes
- There's a lot of subtletly in main trim upwind, and spin/main/helm downwind
if/when you get it all in sync, turbo kicks in – this boat has a high gear – extra hard to keep it going in big swell, but once you get that groove for a little bit, and you know it's there...
We know what to work on
