Jibs roll different directions?Our backstay had just blown off by accidentit was fairly breezey at the top mark we we got there. Not looking close enough though
little hint the difference on ft in not on the main obviously since we cant see it
Certainly interesting to see FT's flicker bent so much. I wouldn't think anyone would've had any backstay on at all...
We have a winner.
Second one is on our main hard to spot unless you know the mains well
the reinforcement dot for the end of the spreader doesn't line up with the end of the spreader
I don't know about that. I am definetly more productive then you are...congrats you are as unproductive as i am
We have a winner.
Why does the Q main have such a small headboard compared to the North?Our backstay had just blown off by accidentit was fairly breezey at the top mark we we got there. Not looking close enough though
While we're doing sail questions, does it really matter which way the jib furls? I could understand it ifyou always did mark roundings in one direction.
it does matter causing the headstay to unwind more or less because of the winds on the wire
you positive about, have to wait to research. But I think the headstay and the jib halyard have opposite turns. If you do the opposite turn you blow out jib halyards more. If you do the regular way you burn out more headstaysYou can get the headstays in both left and right hand wire, so that doesn't really matter. It's more to do with the way you want to furl up the jib, the starboard furl is meant to help get the jib out of the lazy sheet easier as you furl.
