That is why you use big fucking vents. Like 2" diameter clamshells on deck.
The air vent wasn't large enough to relieve the pressure.
Check out the JP54. It has a rotating nav, kitchen, battery bank thingy in the salon to move the weight to windward.any problems with fouling inside a tank if saltwater use sometimes
or with alternate use of fresh/salt in a tank
btw I like the image of rolling cans of supply's
moving from side to side as needed
I thought that most rules don't allow for moving the batteries.battery bank thingy
I'd love to see photos of your setup, and I'd really love to see a video of the tacking process.on my Open 30 and dropped 300+ lites in less than 5 secs
My experience with water ballast is that it's racing only, cruisers can reef and if you want a faster boat then a bigger one is almost always a better option. Water ballast is however a relatively inexpensive and easy way to increase RM. If its a new build and the design is not constrained by rules and the budget allows then a canting keel offers a lot of performance advantages in exchange for more maintenance.I'm planning a new 45' performance cruiser, most of the time I'm sailing shorthanded or singlehanded. The boat is designed for that. Inspired by new First 44, we are now debating adding 300l of water ballast on each side. I don't race and usually stay longer on one tack ... good idea or bad idea? Space is not an issue, we are only planing 1 cabin aft.
Same here. Any details would be very appreciatedI'd love to see photos of your setup, and I'd really love to see a video of the tacking process.
will dig out some imagesI'd love to see photos of your setup, and I'd really love to see a video of the tacking process.
the most poplar is 10deg static which IIRC comes from the original rules by RWYC for the OSTARAs far as i'm aware only the IMOCA class is limited to 10deg static heel, and boy does it complicate the design choices. I will check my Class 40 this spring when we are back in the water and let ya know how far we tip at the dock !
No.Do loads really increase if you are replacing crew with water?
