Kristian Seascape
- 283
ad 1: it caught around the wheel pedestals if you did the beam reach to beam reach when the mainsheet was slack. We moved the sheet point on the boom 150mm forward and did not happen ever since. Grab rails on the helm are great - first as a deflectors for the sheet and second for something to grab instead of grabbing the wheel or mainsheet.Some minor observations:-
- The grab rail on the helm position will end up with the main sheet caught around if not correctly gybed
- The fourules/rope guides on the barber hauler for the jib sheet will end up damaging the deck - needs some protection
- No jib tracks? What about sheeting for #3 and #4's?
ad 2. we are aware of this and are observing the wear. So far (2 months of intense sailing) there is no damage. Jib clew shoudl be higher and the friction ring should be on bungee connected to lower diagonal. But so far no damage.
ad 3. it should work with proper sail cut/clew position.
Talk about the 14kts on two sails... we did that on 26kts TWS, beam reaching.
