We use a sunshower currently with our 30fter. Most days we run the hose down into the head and shower in the head. It offers easy privacy, and makes the experience much more pleasant in cooler/windier conditions. The head dries out surprisingly fast, and the soapy water gives the bilge a wash down and the boat a nice clean smell. On a 36fter, I would prefer a more elegant solution (in addition to the dual purpose wet locker).I dunno. On any boat under 40ft, you gotta give up a lot of space to get a separate shower stall. I’ve owned 2 boats with showers (35 & 31) and through 8 years, we never once used the shower in the head. Aft cockpit shower? Absolutely! But never the one in the head. Who wants all that moisture down below?
Wet locker on the other hand is well worth it!
What kind of boat though? I think we all understand the 36 is a race boat with rating accommodations.We use a sunshower currently with our 30fter. Most days we run the hose down into the head and shower in the head. It offers easy privacy, and makes the experience much more pleasant in cooler/windier conditions. The head dries out surprisingly fast, and the soapy water gives the bilge a wash down and the boat a nice clean smell. On a 36fter, I would prefer a more elegant solution (in addition to the dual purpose wet locker).
I think (but am not 100% sure) that the US Coast Guard regulations require that the boom must not be able to drop down. So most of the dealers request the rigid vang.What regulations dictate vang construction??
US Sailing Offshore racing category requirements have little to do with the US coast guard regulations.Rigging: Boom Support 3.36 A boat over 30' LOA (9.14m) shall have a means to prevent the boom from dropping if support from the mainsail or halyard fails. Required for Ocean and Coastal
That it does but they are a pain as you need 2 sheaves at the top of the mast (I presume the standard mast has only 1 sheave), another hole at the bottom, turning block, cleat/jammer as well as the weight and windage of the rope. Rigid vang is easier.A topping lift satisfies that requirement. Nothing about rigid vang.
^This. My slim 34 footer has a rigid vang with a boingy spring in it. It keeps the boom from crashing into the cockpit but it still sits quite low. At anchor or in the slip, I therefore use the main halyard to pull up the boom fairly high so I have lots of headroom in the cockpit.T/l doesn't have to go down spar. Many boats use a line fixed to masthead crane, down to block just above boom, (2:1) line led inside boom forwards to cleat.
Rigid vangs can leave boom bouncing at anchor, making squeaking noises. T/l prevents that. Many will just take main halyard back to boom end to serve.
Did the same thing. I replaced the rope/block and tackle vang that came with the boat with a Hall Quik-Vang. But kept the original topping lift to keep the boom from smacking heads during party time.^This. My slim 34 footer has a rigid vang with a boingy spring in it. It keeps the boom from crashing into the cockpit but it still sits quite low. At anchor or in the slip, I therefore use the main halyard to pull up the boom fairly high so I have lots of headroom in the cockpit.
Mine is the same and I use the main halyard in the same way. I do wonder why the vang cannot be set higher than it is, does anyone know? I get that you don't want to break the boom if someone gets crazy with the mainsheet but the leech of the main stops it probably 18"-24" above where the vang stops it now.^This. My slim 34 footer has a rigid vang with a boingy spring in it. It keeps the boom from crashing into the cockpit but it still sits quite low. At anchor or in the slip, I therefore use the main halyard to pull up the boom fairly high so I have lots of headroom in the cockpit.
For working on the sail (furling, reefing, fiddling with the battens, putting on a sail cover) I find it rather convenient to have the boom sitting low-ish on the vang. I just use the halyard to get it out of the way permanently.Mine is the same and I use the main halyard in the same way. I do wonder why the vang cannot be set higher than it is, does anyone know? I get that you don't want to break the boom if someone gets crazy with the mainsheet but the leech of the main stops it probably 18"-24" above where the vang stops it now.
