New cabin sole anarchy
Grizz
Beats the crap out of me
426
155
Northport, NY
So- the 3/4" teak and holly veneer plywood that makes up the cabin sole in my Frers 33 has delaminated to the point of no return. I now own a new 4x8 sheet of the same material, purchased for an eye-watering $500 for a single sheet! I will certainly endeavor to measure a bunch of times and cut once- I was able to remove the old one intact to serve as a template.
What's the current wisdom on a finish? The underside is often directly exposed to water in the various shallow bilge compartments, so I am assuming an epoxy coat below and on any edge plies is a given. I have had a few thoughts for the exposed side- varnish over epoxy, with the first epoxy coat thinned? Straight varnish without epoxy?
Any and all suggestions would be greatly appreciated!
phill_nz
821
internet atm
start with any epoxy resin thinned 10-20% ..  cup test the ratio for gel and cure before using on the ply
use epoxy thinners only
keep feeding it till it gels .. it soaks up quite a bit
Zonker
4,842
Canada
Minimum 2 coats on the underside and 3 on exposed edges of cutouts (due to wear and tear).
See this thread and my recommendation for the top surface
9,587
Make the fit quite loose, otherwise the buildup of finish can make everything slightly too large and having to sand it back and start over is a pain in the ass.
Grizz
426
155
Northport, NY
Undercut (bevel) them slightly - then they can fit snug but release easily without wearing the finish off the edges.
Thanks Sloop-actually, the edges have changing bevels, and the forward section tapers in thickness from the center down to about 1/4” at the edges, but maintains the entire 3/4” thickness for the rear two thirds. Like a freakin’ violin soundboard, in case I was worried about it being too easy!
Grizz
426
155
Northport, NY
Thanks Ish- it also just barely makes it through the companionway, and the winter cover is on so test fits are going to be a pain in the ass!
Grizz
426
155
Northport, NY
Thanks Zonker- I’m not planning to go with any non-skid strips. The old one was finished with gloss varnish, and as a couple of folks have mentioned I’ve never found it to be an issue. I looked through the thread and didn’t notice whether you suggested an epoxy first coat, or just straight varnish for the top surface.
Grizz
426
155
Northport, NY
Thanks Phill- that accords with some of the suggestions I’ve heard.
Grizz
426
155
Northport, NY
Fleetwood said:
I use Synteko here in Oz. Its a part of Akzo Nobel so probably widely available in the US. (Their oil on the top, epoxy painted (Interprotect 2K) underneath and sides.)
Thanks Fleetwood- do you apply the Interprotect over bare plywood? Also which Synteko product do you use? Is it two-part acid curing?
Grizz
426
155
Northport, NY
Don't epoxy the boards in a damp environment. The humidity gets into the wood and causes hazing in the finish when it outgasses afterwards.  Make sure the ply is kept DRY.
Thanks PaulK- the PO had the sole refinished before i bought it, and the coating failed extensively because of moisture intrusion. I’ll be doing the work in my basement over the Winter, so moisture shouldn’t be an issue,
Zonker
4,842
Canada
Varnish a scrap piece of cheaper but smooth plywood about 2' square. Prop it up in the living room so it's about a 30 degree angle. Spill a glass of water on it. Stand on it and report back. :)
DDW
976
It isn't just the finish. You start with dry plywood in your workshop and end up with moist plywood on the boat, it gets bigger even without the finish. This is why you leave flooring inside the house its going in for 8 weeks before you install - to let it settle at the ambient moisture content.
When epoxy is thinned, it’s more permeable when cured. When the solvent goes away, the resultant solid is porous. THis defeats the purpose of sealing the plywood.
There’s more on this at Westsystem.com or maybe Epoxyworks. They tested the moisture uptake of epoxy coated samples in wet conditions.
The other way to get epoxy to be thin is heat. Apply in warm conditions. Warm the plywood, not the epoxies.
sculpin
Oversize drill the screw holes and epoxy fill them, otherwise water will get in that way and you will have a wet ring around each screw.  On my second go at this I drilled the screw holes way oversize and fit solid teak plugs in them (epoxied in place), then flipped the sole upside down and filled the remaining cavity with epoxy.  Re-drilled the proper size for the screw through this.
slug zitski
775
worldwide
When the floor boards chafe against floor timber’s the paint film breaks and you get water intrusion
to prevent the flooorboards from touching the frames many boatbuilder use rubber stand offs
these are rubber cord, o ring material about 10 or 12mm in diameter
a hole is bored into the bottom perimeter at floor timber contact and a short piece of rubber is inserted
the is done around the perimeter at perhaps 8 inch intervals
once the rubber cord is inserted and glued it’s trimmed back with a razor blade so only a few mm is standing proud and full floor timber contact is achieved
on some installations these rubber bumpers are used on the floorboard edges to prevent contact chafe
always heavily radius the bottom edge of the floorboard to prevent edge damage
these rubber bumpers also prevent squeak  and vibration
