Pinching
- 16
Grizz,
I replaced the cabin sole on my 1988 Carroll Frers 41. Used the old boards as patterns, tapered edges as needed. Epoxy coated underside and added 6" tape on the tapered edges underneath. The underside is exposed to bilge water like crazy. I used regular varnish (probably Minwax or similar) on the pretty (upper) side and added some short non skid strips near the nav station to keep the navigator in place. Fastener holes were over drilled then epoxied then fastened. Just used flat head SS fasteners no bungs. This is an old MHS boat so no worries about squeaks or such sillilness.
The sole was replaced in 1998 and is still going strong without delam. Much of the teak veneer has faded under the sun
I've sanded and revarnished about every 3 years or so. The non skid strips are also replaced. I avoid removing all varnish so I don't sand through the thin veneer
Most of the walking surface is varnished teak/holly plywood (ours was only 1/2" thick). It has not been a terrible surface in terms of being slippery. What is a terrible surface are the sail turtle bags on the cabin sole -- they are usually pretty soggy on distance races when it's frisky out.
P
P
