Virgulino Ferreira
This new look stinks.
Didn't you say that after the last upgrade?Apologies if I am repeating myself, but "New and Improved" are usually neither!!![]()
Just put them back....forget sending a list RESTORE as it was!send me a pm, I can send you your ignore list
It automatically loads the first unread post, there is no need to manually go to the latest post you have readWhere's the "go to first unread" function?
actually it makes page loading speed much better because only the photo you want is fully loadedHaving all pics as thumbnails blows
Is it a thread?What happened to the "Popularity Contest"?
I've likely said this about every upgrade since the BB format, but this sucks!
Can you send my my old avatar too? (It was an unique picture; one I took myself.)
"Classic SA" upvotes and downvotes are still possible by hovering over the Like button and the stats are still available but requires a few clicks.What happened to the "Popularity Contest"?
Will we see the like count?...."Classic SA" upvotes and downvotes are still possible by hovering over the Like button and the stats are still available but requires a few clicks.
then the new software doesn't know what you have read or not. Go to the latest page, read the latest post and then it's "fixed"Guess again - it goes to the first post on page one in the thread
I've added this below the avatar"Classic SA" upvotes and downvotes are still possible by hovering over the Like button and the stats are still available but requires a few clicks.
It seems that you need to recreate all your 'bookmarks' once you've read a thread in the upgraded version the next time it automatically takes you to the first unread post. A bit of a PIA but it works.Guess again - it goes to the first post on page one in the thread
Bit of help @techadmin please. I thought I found the breakdown of up- and down-votes for others, but looking again all I can find is my own "Reactions Received". Is it possible to see the breakdown of others?Will we see the like count?....
Still there just different. You can either select blocks of text (the same or different) more than once or reply more than once (the same or different).I've gone through the forums I normally view and marked all posts as read so I can skip the going to first post.
We have lost the multi quote option![]()
Beauty! Much appreciated.I've added this below the avatar
select the text you want to quote and click on reply, you can do this multiple times.We have lost the multi quote option![]()
I can find my own "Reactions Received".
