I have a Nexus NX2 wind transducer connected to FDX NX2 server. Also depth and log is connected, which are working fine.
Before the winter I removed it from the boat in working state. Now I put it back and it is not working any more.
It shows just dashes on the display (same when it is not turning any more because lack of wind).
Also the leds on the server don't light up.
I thought maybe the connection of the cable is not good. But I doubt if this is the problem.
Because when I measure the yellow and white cables (disconnected from the server), I measure about 10 volts on both of the wires between this wires and gnd (screen).
I think this means that the transducer is receiving ground (screen) and +12v (green). And also the transducer is connected to yellow and white inside the boat. So the connection with the cable or the cable itself should not be the problem. Otherwise I should not measure 10V.
This could mean there is something defect in the transducer.
Any comments on this?
I have to make some effort to take this transducer down.
Then I want to connect this to the server again, to make sure nothing is wrong with the long cable and connection. But I cannot use the cable.
I want to connect with some wires the connector directly to the server. But I don't know the pin layout.
Does anyone now what the pin layout is of the connector attached to the transducer?
And does anyone know how to disassembly the transducer to look inside?
I have some electronics background.
And are the yellow and white cables a digital output or analog output?
Can somebody tell how this transducer is working?
(what will be the output on these yellow and white wires)
A lot of questions, but replacing it will cost a lot of money.
