All true. But 100% irrelevant to me. I am glad others have different value systems. But there was absolutely nothing about the diesel that I liked, yet everything I did not like.The battery mentioned above is about 10kwh. Let's assume the battery to shaft is 90% efficient and the battery can be discharged to 80%, so there's about 7.2kwh getting to the prop.
A liter of diesel is about 5kwh and a normally aspirated diesel has around 33% thermal efficiency. Let's call it 25% at low RPM to get to the shaft.
So the battery is worth about 5.75 liters of diesel and a wild-ass guess of 6 knots for 4 hours with carefully selected prop. Note that the ISAF OSR for CAT 0, 1, 2, & 3 requires 8 hours motoring at 6 knots for the Olson 40's 36' LWL.
how much do you know about the Cape (and Chile)?including a trip around Cape Horn.
Hal Roth tried that on an SC50 for a singlehanded fiasco. Similar boat to O40. Utter failure I think. You can read all about it in his book. The ruined abomination of an SC50 is usually for sale somewhere.seems like you could put together a water ballast setup with some tanks under the gunnels to get some righting moment back.
Crash,All true. But 100% irrelevant to me. I am glad others have different value systems. But there was absolutely nothing about the diesel that I liked, yet everything I did not like.
I don’t need any motor. This is purely a luxury to get in and out of a marina. No other use whatsoever.
Its cool that the boat is getting lighter. Nearly 800 lbs of useless, smelly, noisy, toxic shit removed from a 10,000 lb boat is noticeable.
Can you give us the sparknotes version of why it was such a fiasco? Was it the water ballasts fault, the engineering behind it, or something else all together?Hal Roth tried that on an SC50 for a singlehanded fiasco. Similar boat to O40. Utter failure I think. You can read all about it in his book. The ruined abomination of an SC50 is usually for sale somewhere.
The interior is dominated, ruined, by the huge tanks. So you can delete having a comfortable cruising boat from your list. Like living in a hallway.Can you give us the sparknotes version of why it was such a fiasco? Was it the water ballasts fault, the engineering behind it, or something else all together?
~him
Are you testing a Watt&Sea? Might be a good fit for a fast boat like yours.Right now it is 4 x 12v x 100Ah series LiFePO4 by Battle Born batteries in Reno. 5KWh.
By numbers, about the same as the 4 x 6v x 225Ah series-parallel 12v system I had before. But at discharge rates of the KW level, lead acid has about 5% effective capacity. So the lithium batteries give me about 20x range under power.
The charger refills an empty bank in 2 hours of shore power.
I have plenty of room to go to 10 or even 15KWh. The batteries are light and oddly inexpensive in boat bucks (or horse bucks or airplane bucks or employee payroll bucks) but of course crazy expensive in Starbucks. A headsail is about 5KWh of batteries, but the headsail prices go up as battery prices go down.
Its recharge on the hook, instead of slip, that is keeping me from going bigger yet. So after I start installing solar, and testing the regen-via-prop-under-sail effectiveness, I may go bigger. It just seems silly to have more battery than I can charge. I might change my tune, we will see.
It is all a grand experiment.
