Rain Man
- Thread starter
- #21
Thanks for the help, you can tell I haven't owned a diesel before.Yes.
Yes to 2" pitch reduction.
Are you positive about gear ratio (looked at the plate on the gearbox?) 2.62 is also available on those transmissions
Ask Propspeed or other supplier for appropriate solvent to remove. If it's silicone based there are silicone removers. Turns it sort of chalky and you can brush off.
Good question about the ratios. This is the plate on the transmission:
Unless they changed the ratio internally (is that possible?) it should be 2.21. I am still mystified how they got this wrong.
