I have a Doyle Stackpack on the old sail. It's design acts as a funnel, directing water into the folds of the sail. Combine that with a laminate sail, I get about 20 gallons in there, in a month or two it has its own ecosystem of flora and fauna. I'm done with laminate sails, too many broken promises over too many decades about how the mildew and delamination problems have been solved. New sail coming, Hydranet, which has the opportunity to dry if it is only given a chance.
So I'm trying to come up with a pack construction that will keep all or most of the water out from the top, and some ventilation and drainage on the bottom. The latter seems straightforward, mesh on the bottom. However the zipper top is complicated. Doyle puts battens near the top, there are wings of cloth that extend up a couple of inches, webbing is sewn from the batten up through these for the jacks. The zipper flaps inevitably form a trough and collect all the water they can and direct it into the sail.
An obvious improvement is to place the battens and webbing so there are no trough walls like the Doyle. But to really shed water, the zipper must form a peak, or maybe a peak with the zipper to one side on the downslope. I haven't figured out how to do this. The cover I have was modified once, then a new one built each time making the circumference smaller, but making it so small that the sail itself provides the bulk to make the peak doesn't seem possible, and still get it closed easily. If the webbing terminating the jacks is sewn right up to the zipper, it would make the zipper peak - but would be very hard to get closed, and probably ruin the zipper in short order.
Blue is cover, red is jacks. A perfect water trough:
