Connor.kainalu
How do you gauge performance gains with only one boat? Is there any tech that can measure minute speed differences and heading changes? I'm posting this on this forum because I plan to work in a development class (I14).
If you are coming to SD, and if you decide to get a 14, there are several local boats to line up against. Some very well sailed boats, some beginners, and several in between. Just have to get out on a boat and learn to sail it first. Don't get too caught up in all the development until you know you can get the boat around a course very efficiently. Then start worrying about 1 boat, 2 boat and several boat testing and advancements. There are already local boats setting themselves up in very similar fashion so as to minimize the differences in boats, foils, rigs, sails, etc. and then try to work together to go better as a group. Get in a boat and sail it!How do you gauge performance gains with only one boat? Is there any tech that can measure minute speed differences and heading changes? I'm posting this on this forum because I plan to work in a development class (I14).
This is because speed vary so much with conditions, be it wind or sea state.Sog upwind maybe nearly wind speed up to 10kts in flat water up max to 12 kts on a very good day in wind. Bit footy.
While I agree in general that two devices may show different values, there's no confidence level associated with that ±0.2 kn, reasons why it occurs nor methodology for how it was determined (e.g. it might be from latency due to averaging over a period, or from atmospheric effects that are only partially accommodated, or based on the minimum number of satellites in range, or …). So just because the accuracy is quoted as "±0.2 kn" doesn't mean it doesn't usually show speed to a much greater accuracy (or much lower if some higher level of confidence is used).Another issue is accuracy. Put 2 Prostarts on a boat and the chances are they will show very slightly different numbers as the accuracy is + or - 0.2 knots.
+1 for RaceQs for analysis combined with an action camera - and you can mount a smartphone below deck (in a waterproof container/case) to do the tracking. Pair it with a Pebble watch for RaceQs live feed/remote control via Bluetooth or use a Garmin watch with GPS which can run RaceQs without the phone.While I agree that there are no substitutes for sailing with other boats, sometimes that isn’t feasible, and you wind up training solo. On the I14 I sail, we pair a Tactic Microcompass, and Speedpuck for instantaneous feedback. Post post-sail analysis, I've occasionally synced GoPro footage with GPS data via RaceQs. I've been surprised at how useful the data has been for tuning (I had very low expectations).
I've found the greatest advantage of the video/GPS combo has been clarifying when high or low modes pay, quantifying the cost of various maneuvers, and subsequently prioritizing training objectives. (A dauntingly long list!)
