Marcjsmith
Ok I k ow. It’s british engine, if it’s not leaking oil, that’s means it’s out of oil...
I think the time has come to replace the rear main seal on my perkins 4108.
My though process is doing it one of two ways.
1. Leave transmission attached to shaft, remove bell housing from engine and trans and slide shaft aft as far as possible then remove flywheel and change seal
2. Take take trans off the shaft by disconnecting coupler then remove flywheel, and seal.
I’m hoping to avoid removing the shift linkage and hoping to avoid having to realign the shaft to the engine....
That being said. I know that if I’m taking the trans off, might be a good time to service it, beyond just a normal fluid change. It has not been giving me any problems....so I’m not inclined to open it up.
I’m also aware that even though my pss seal is not leaking, but if I do option 1 I’ll have to remove part of it to slide the shaft aft... which could result in the dripless shaft dripping upon reassembly.. Do I increase the scope of the project to include a new shaft seal...
Thoughts...
Thoughts...
