sounds like me, please hail me next time, I always like meeting CA members.I think I saw you leaving EBM last Thursday (or was it 2 Thursdays ago) in the cat. We were coming in for the Downtown Series. You SYC? This boat had a burgee off the bow.And she looks good with her fellow fleet members. Not counting my inflatable these are all of my operational vessels at this time. Looking forward to adding the Big Sliver to the mix.....
Sure thing.sounds like me, please hail me next time, I always like meeting CA members.I think I saw you leaving EBM last Thursday (or was it 2 Thursdays ago) in the cat. We were coming in for the Downtown Series. You SYC? This boat had a burgee off the bow.And she looks good with her fellow fleet members. Not counting my inflatable these are all of my operational vessels at this time. Looking forward to adding the Big Sliver to the mix.....
Hah! I was trying to echo Bolger's exasperation with people who insist on sailing paddle boats.Kim:
That is a sweet skiff. Can't see how you could do any better than that.
Don't listen to Tom. That boat is happiest being rowed.
Although I admit I am occasionally one of those people.
Bolger claims one of his designs is actually a decent sailboat, rowboat, and powerboat. I'm skeptical. I may have to build it to find out.
Baby Sliver does not have much stability, no keel and no rudder so.................., I think I will row or only sail down wind.I think Kim needs one of those seats on a plank that the canoe sailors use. Then he could hike in comfort while sailing the little Sliver. Or maybe a Viking sail and only go down wind.![]()
BV
Bolger explains at length, over and over, why multi-propulsion boats are bad. I've said similar things about the MacGregor powersailers.That particular design keeps crying to me also, but it would take a lot of plywood and you still have a fugly boat.Bolger claims one of his designs is actually a decent sailboat, rowboat, and powerboat. I'm skeptical. I may have to build it to find out.
Glad there is a continent between me and it.Bruce is trying to sell his delightful little Joel White designed Catspaw dinghy.
My father's diet plan for his whole life: he refuses to buy new pants. If he gets fat, he can't leave the house until he remedies the situation. It has worked.Of course you can get thru that hole Kim. Why do you think I designed it like that? You told me you had a 32" waist and I designed the opening accordingly.
Kim, the boat looks great and thanks again for a complete Monday update. I had powerboating pics all lined up if you failed in your duty.Underside of the cockpit, not too many people will see it, but good to know the crew cares about it.
I'll throw in that I don't see limber holes at any of the frames or stringers. Was this a conscious decision? I'd be interested in the thoughts behind it. Assuming some water will find its way below at some point, how will you get it out?Kim, the boat looks great and thanks again for a complete Monday update. I had powerboating pics all lined up if you failed in your duty.Underside of the cockpit, not too many people will see it, but good to know the crew cares about it.![]()
Bob, how do you (and designers in general) decide on the depth of the gutters around hatch lids? Those look a bit shallow to me, but then, pretty much all of them do. They always seem like they could use another inch or so. I hit the seam with a hose and water manages to splash down hard enough to bounce up around the corner and land where it does not belong. I might have mentioned my belief that a boat should have no puddles and no water where it does not belong when I'm done hosing it.![]()
Am I the only one? Should I just HTFU as I go around with a sponge or chamois and get rid of the offending water? Or should I continue to mutter obscenities about designers?![]()
The reinforcing plates on the forward bulkhead of the center section are not notched therefore I believe the stringer will terminate at that reinforcing plate.Kim, it looks like the fwd bulkhead of the internal grid is set up for stringer cutouts, how will this happen? Will the grid be lowered in then moved fwd over the ends of the stringers?
Looking fantastic by the way. These guys attention to detail is amazing!
The bulkheads all have a cutout (in the reinforcing plate) over the keelson to allow for "limbering". The upper stringers have a sloped top to shed water. The forward lower stringers slope aft, the aft lower stringers slope forward to shed water towards the center. And the ends are virtually completely open so inspecting for water retention will be easy. My Dad used to sponge out his bilge after every sail (on his Dragon) so I might have to follow suit if necessary.I'll throw in that I don't see limber holes at any of the frames or stringers. Was this a conscious decision? I'd be interested in the thoughts behind it. Assuming some water will find its way below at some point, how will you get it out?Kim, the boat looks great and thanks again for a complete Monday update. I had powerboating pics all lined up if you failed in your duty.Underside of the cockpit, not too many people will see it, but good to know the crew cares about it.![]()
Great pics and a very nice build.
