Point Break
This explains it……
Quebec has to be different…Maybe just sleeping?
Beloved Quebec groundhog found dead hours before he was due to predict end of winter
A child attending the event was called in as an emergency replacement and predicted winter will continue.nationalpost.com
Follow P_WOP for more recipesI wonder what they taste like on the grill?
they taste just like dove...I wonder what they taste like on the grill?
Groundhog Stew, with Bacon and Natural Wild Rice
Marinate the woodchuck, brown it, braise in stock, remove meat from the bones, then sweat some diced vegetables, add back the meat and cooking liquid, along with some rice, season it up, and voila. Have some good bread around, you're going to want to wipe the bowl clean.
Prep Time
12 hrs
Cook Time
30 mins
Course: Main Course, SoupCuisine: AmericanKeyword: Groundhog, Small game, Stew, Woodchuck Servings: 2
Ingredients
One roughly 2-3 lb groundhog skinned, gutted, rinsed and quartered (see photo above)
Marinade
3 cups dry white wine
1 bulb of garlic cloves lightly crushed with the back of a knife
1 large sprig rosemary leaves torn off the branch
a small handful of fresh thyme sprigs roughly 6-7
2 fresh bay leaves optional
Kosher salt and pepper
¼ cup blended olive oil or neutral vegetable oil
For the Groundhog Stew
3 cups mixed vegetables diced ¼ inch (I used a mix of carrots, potatoes, onion, celery and fennel)
1 large tomato Bottom scored, blanched in boiling water for a few seconds, then cooled, seeded and chopped.
3 qts chicken stock preferably homemade
4 ounces smoked pork belly or slab bacon diced ¼ inch
¼ cup wild rice flour for dredging the woodchuck, optional
½ tablespoon garlic minced
¼ cup dry sherry
½ cup wood parched / natural wild rice or 1 cup cooked wild rice
1 ear of sweet corn
2 tablespoons unsalted butter
Tobasco to taste, optional
Sliced scallions ¼ inch, tender white and green parts only, optional
Instructions
Marinating
The night before hand, trim the groundhog pieces of as much visible fat as possible, then season liberally with salt and pepper, toss with the garlic cl0ves, oil, thyme, bay leaves, and rosemary. Put the seasoned groundhog pieces in a wide dish or casserole and pour over the wine. Allow the woodchuck to sit overnight or at least for 4-5 hours, turn it around in the juices now and then if you have time.
Cut the corn from the cob, then cut the cobb into 2 inch slices and reserve both separately.
To prepare the stew, render out the fat from the bacon in a wide 10 inch braising pan, remove the bacon and reserve, leave the fat in the pan.
Browning and Building the Stew
Remove the groundhog pieces from their marinade, pat dry and remove any rogue herbs or pieces of garlic. Toss with the wild rice flour, then brown on medium high heat in the bacon fat. Pour off the spent fat from the pan, deglaze the pan with the sherry, reduce by half, then add the stock, corn cob, cover the pan and reduce the heat to a gentle simmer.
If you have time, skim the albumen and fat that rise to the surface of the pan occasionally as it makes a cleaner tasting stew. Simmer the groundhog gently for 1.5 hours, or until the meat can be picked from the bones.
Meanwhile, cook the wild rice in the chicken stock until just done, then strain out the rice and lay out on a plate or cookie sheet to cool. Reserve the wild rice liquid to add to the stew. It adds really good flavor, and that's why you're cooking the rice in chicken stock in the first place.
Remove the woodchuck pieces and cool, then pick the meat from the bones, give it a rough chop, and reserve. You should have about 2.5 cups of meat.
Remove the stock from the pan and reserve then strain it. You should have about 1 qts of liquid.
Wipe the pan, then melt the butter and add the diced vegetables, bacon and the garlic. Sweat the mixture until it's well cooked, and the vegetables are soft, about 15 minutes, then add the reserved woodchuck liquid, tomato, wild rice liquid and simmer for 15 minutes more.
Finally, add the woodchuck meat, corn kernels, and wild rice. Season the stew with salt to taste, then serve immediately with some Tobasco on the side. If not serving, chill immediately, transfer to a labeled, dated container and reserve until needed.
Notes
You could substitute another small creature here — rabbit, turtle, duck or goose legs would all be great. There are probably some other little creatures I don't know of that would be good too.
Congratulations. Two full top battens is definitely the way to go. 100% full-battened mains tend to be slow, with hooked lower leeches.I'd think you'd look forward to extending your time on the slopes.
In the PNW we look forward to the fall, winter and spring for some of our best sailing. If winter is a wee bit longer then normal, that's great for sailors for extending possible breezy conditions, and for those who want an extended ski and snowboarding season on the slopes, all the better.
I usually turn to NOAA for guidance on seasonal changes, or even the Farmer's Almanac, both of which have a good consistent spring and extended weather forecasts overall. If the groundhog says it's gonna be a longer winter, I always look at that as a good thang, with possibly higher then normal breezy wind conditions from Southerlies and South-westerlies in frontal systems and squalls, and the possibility of more storms and winter storm windsurfing or sailing.
Our local weather men usually beat the groundhogs prediction by wide margins. In fact the groundhog is usually only right for the PNW about 40% of the time, for the nation as a whole 46% and varies from 40% - 50% for Pennsylvania, New Jersey and Delaware.
Right now looking forward to a vertical paneled tri-radial new main with two full length battens high, and the rest partial battens to arrive - to replace the old full batten crosscut main to go with the new vertical paneled jibs and blade we bought the past few seasons and if winter is extended, all the better and loving it.
Honest work indeed. A year's salary, free housing and food for one day of work. Brilliant.
That looks wonderful, what YC?Nice swim workout at the yacht club this morning. All the fair weather swimmers skipped. I guess 60 is too cold for them.
